Thread: frozen boost intetcooler kit
Results 1 to 3 of 3
  1. #1 frozen boost intetcooler kit
    tennessee
    Ok don't think Im a cheap a** but I was looking around at some intercoolers and stumbled across these kits... Liquid Air Intercooler . I've read around and heard of some people runnin around 5-10* above ambient which id say is pretty good and hardly any pressure drop... just wondering what the general concensus was... it would b going on a dd with headers 3.4 and an overkill tune
  2. #2 Re: frozen boost intetcooler kit
    SE Level Member kygtp's Avatar
    Oct 2008
    Cincy
    I think those are more for turbos, not S/C cars. Instead of running huge front mount for a turbo, some people run these where the boosted air goes in one side though the cooler and out the other side.
    Now I run a frozen boost front mount for my IC setup and it works great. This is what I run with my stage2 ZZP core: Air to Water Heat Exchanger
  3. #3 Re: frozen boost intetcooler kit
    Omaha, NE
    You would still need a 3800 vendors IC Core for a S/C setup.
    There are people using FB front mounts, which can be larger in Cubic Inch than the 3800 vendors.
    Best cooling option is a Dual Pass heat excanger over a single pass because it is cooled twice. These generally cost quite a bit more.
    Basically if you look around and find what you need, you can do a custom setup with better, more consistant temp drops than waht is on the market. If you want to splurge on vendor parts, with everything in a kit, you can go that route too.
  1. Front mount intetcooler
    By Davisgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2009, 04:40 PM
  2. frozen boost fmhe 118 or 100
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2009, 10:47 PM
  3. Frozen Gas filter
    By Lion29GTP in forum General Tech Discussion
    Last Post: 04-07-2009, 09:52 AM
  4. From the Frozen Tundra
    By highlife70 in forum Introductions/Noob Questions
    Last Post: 01-08-2009, 11:03 PM
