Thread: Car wont start, Help Please
Results 1 to 17 of 17
  1. #1 Car wont start, Help Please
    Jan 2013
    florida
    just got a 1999 Grand Prix GTP, drove it home it was fine, next day turn the key and it shuts off. had flashing red lisecurity light, read how to disarm the anti theft system,car started up. went to go to work the next day and turned the corner the car shut off but started right up. stopped at the atm and shut the car off, went back to start and same thingwouldnt start. got a ride to work went back to tow it and just for kicks tried to start it and it started right up, drove it home and havent driven it since. every where I read said it was a pass lock problem, my car thinks I am trying to stealit. could this be the issue? if so how do I fix this? I have not got to drive my car since I got 2 weeks ago UGGGGGG Help Please !!!
  2. #2 Re: Car wont start, Help Please
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    pull pgm mall fuse for 5 min then try again
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #3 Re: Car wont start, Help Please
    if oyu got the security light to go off. it could be a crank bad sensor.
    any chance you noticed if the tach went to zero before it stalled out?
  4. #4 Re: Car wont start, Help Please
    Jan 2013
    florida
    no did not notice if the tach went to zero, the light is off but everywhere I have read said it sounded like the pass lock and I am not sure how to tell if that is it. crank sensor would that keep it from starting?
  5. #5 Re: Car wont start, Help Please
    Jan 2013
    florida
    tried that didnt work, thank you for helping
  6. #6 Re: Car wont start, Help Please
    Jan 2013
    florida
    also if it was the crank shaft sensor wouldnt I get a check engine light? I have no light on, had one forthe map sensor replaced it and the light went away
  7. #7 Re: Car wont start, Help Please
    crank sensor is the one sensor that wont set a code most of the time.
    security problems will usually start up run for 10 seconds and stall. or not start at all.
    is the key your using have a chip in it?
  8. #8 Re: Car wont start, Help Please
    Jan 2013
    florida
    thats what the car does start for about 10 secs then stalls,no chip in the key
  9. #9 Re: Car wont start, Help Please
    if the security light is on, or blinking, your still having a security issue. you should have a key with a chip in it.
    most auto lock smiths can cut and program a new key for 1/2 what a dealer would charge.
  10. #10 Re: Car wont start, Help Please
    Sep 2012
    bridgeport,NY
    gp didnt have chip in key till 04
  11. #11 Re: Car wont start, Help Please
    Quote Originally Posted by Erik Adam Rodriguez View Post
    what else would set off a security light?
  12. #12 Re: Car wont start, Help Please
    GT Level Member nicks98gtp's Avatar
    michigan
    Fuel pump resistor going out by chance? I had the same thing happening when mine went, it would start and choke out unless i held the pedal to the floor. Not sure why the security light would be on, but if its off now and your still getting stalling/no start maybe something to look into. Google Image Result for http://i64.photobucket.com/albums/h178/normanmj/relays.jpg
    Heres a link if you need more info google the fuel pump resistor bypass and see if it resolves the no start stalling issue
    98 Gtp, ported s/c, fully rebuilt motor .20 oversized pistons, rebuilt trans, zzp pcm,more mods to come
  13. #13 Re: Car wont start, Help Please
    Sep 2012
    bridgeport,NY
    you know whats does the door ajar indicator but i never heard of it causing this kind of issue also check voltage to pcm
  14. #14 Re: Car wont start, Help Please
    Jan 2013
    florida
    Ok took the relay out bent the 85 taband vrooooom thank you ! started right up, my only question is I smell alot of fuel now is this going tobe ok till I get the new resistor kit?
  15. #15 Re: Car wont start, Help Please
    No, it's because you either have a leak or are imagining it. Bending the tab has no effect on smelling fuel.
  16. #16 Re: Car wont start, Help Please
    michigan
    i actually have a spare resistor if your interested. i bought it for my gtp when i thought it was bad but turned out to be something else. Its basically brand new just thrown in the car to run a test. sold my car and no longer have a need for it. let me know if your interested
  17. #17 Re: Car wont start, Help Please
    Jan 2013
    florida
    Thanks, Eneded up gettting one already and changed car works now, but now the check engine light is on and the abs light is on uggg lol now guess I will have to figure that out
  1. car wont start
    By bmx6454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-11-2012, 09:45 AM
  2. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  3. 97' GP GT wont start
    By AREED in forum Introductions/Noob Questions
    Last Post: 08-16-2010, 06:28 PM
  4. ran out of gas , now it wont start
    By jbon64 in forum General Tech Discussion
    Last Post: 12-25-2008, 02:27 PM
  5. Car wont start
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:57 PM
