Thread: Headers not going to fit on drop in
Results 1 to 9 of 9
  1. #1 Headers not going to fit on drop in
    Donating Users Slappyn's Avatar
    Dec 2012
    Goldsboro, NC
    Im dropping in this motor and I really wanted to drop it with the headers but I dont think I can do it. yea or na? Oh and its probably going to leak since the cross over does not line up with the headers. As long as no code Im fine until after I get it inspected for the first time.
  2. #2 Re: Headers not going to fit on drop in
    So long as you put band clamps on there you shouldn't have any leaks. If in doubt put some copper rtv on it.
  3. #3 Re: Headers not going to fit on drop in
    Dec 2012
    Goldsboro, NC
    cool. Think I can get the flex to clear the front of the car on new motor install with a standard chain cherry picker? I suppose I could measure it tomorrow but I wanted show pics of my two weeks work.
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Few years ago I put in a motor with the headers on. And a engine hoist.. took 3 people to help guide it in. Wasn't fun. But possible.. This time I put the headers on after the motor was in seemed less stressful. Here's an old shot
    I used two u clamps on the front header and crossover on that car and didn't have any leaks.. This time around it was seal/band clamps.
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  5. #5 Re: Headers not going to fit on drop in
    Dec 2012
    Goldsboro, NC
    Nice. I thought putting on the headers would be a breeze while the motor was out and it was but I thought it would be easier.
  6. #6 Re: Headers not going to fit on drop in
    Dec 2012
    Goldsboro, NC
    Did you do the cat delete? Oh and I plan on leaving the oil filter adapter off until after install.
    GT Level Member Utter99's Avatar
    Warsaw indiana
    I always just put the rear header down into the tunnel and let it sit . It's easier to get it back there before the engines in, I had troubles Geting it down the back with the motor in although I had it ratchet strapped as far forward as possible
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  8. #8 Re: Headers not going to fit on drop in
    I lay the rear in on top of the trans and then maybe start a couple of bolts as the motor is dropped in. It's not easy to do with it attached, possible like the guys have said.
  9. #9 Re: Headers not going to fit on drop in
    Cambridge, Ontario Canada
    See link in sig. Wasnt bad at all for me. A little playing around but ok.
    2005 E55 - stock
  1. oil pan drop
    By SJAndrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2012, 10:22 AM
  2. headers, pully drop, pcm order of operations???
    By drewzilla03 in forum General Tech Discussion
    Last Post: 07-18-2011, 09:19 AM
  3. XS Power Headers Vs. SSAC Headers
    By 04CompG in forum General Tech Discussion
    Last Post: 12-02-2008, 01:12 PM
