Thread: 04 no boost?
Results 1 to 5 of 5
  1. #1 04 no boost?
    Nov 2012
    Milwaukee
    car is an 04 gtp comp g with 70k on it, completely stock.
    So I noticed the boost guage isn't showing any boost. I used my bluetooth scanner and it doesn't show any boost either. It shows vaccuum, and max Manifold pressure it shows is 96KPA which is just short of 1 atmosphere.
    The supercharger doesn't make any odd noises.
    I was first thinking broken factory boost guage or line leading to it, hence why I got out the bluetooth scanner, but the MAP reading coming up short tells me I'm not getting any boost... right?
    any thoughts?
  2. #2 Re: 04 no boost?
    Nov 2012
    Madison
    well that sucks
    Did you already check vac lines?
    Try this TexasTanker had a problem not to long ago. http://www.grandprixforums.net/low-b...rns-71622.html
  3. #3 Re: 04 no boost?
    Nov 2012
    Milwaukee
    I think I figured out my problem. But still need help. When I checked the vac line that runs to the MAP, I noticed on the bracket, there is another sensor there that looks like another MAP!? they're both identical with identical wire harnesses plugged into them but different color wires, and one has the vac line connected, the other has a male connected for the vac line, but no line... wtf?
  4. #4 Re: 04 no boost?
    Nov 2012
    Milwaukee
    figured it out, the 2nd sensor on the back is the barometric pressure sensor... pretty much a sensor to measure atmospheric pressure for comparison sake to the manifold pressure.
    the idiot to had this car before me put the vac lines on wrong, connecting the map to the spot above the supercharger... oops
  5. #5 Re: 04 no boost?
    GTP Level Member AjL227's Avatar
    IL
    How is the condition of your actual vacuum T that goes onto the LIM nipple?
    By 80k miles and several removals/reinstalls, my T was cracked and I had to shorten it which eventually lead to it being sucked in and out partially blocking off an accurate vacuum reading to the MAP.
    Don't be forced to buy the entire vacuum line kit from ZZP or the dealer.
    My friend and I are currently working on molding silicone vacuum T's out of fire tape.
    I'll let you know more details when we mass produce them and start another thread for sale.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  3. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  4. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
