Thread: Chances that the motor is OK??
Results 1 to 10 of 10
  1. #1 Chances that the motor is OK??
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    A guy I know didnt put enough antifreeze in when he put coolant in the radiator and it ended up freezing solid on him. We thawed it out and everything but discovered water in the oil now ( obviously something cracked). Now my plan is to topswap my car, and take all the parts from my motor and swapping it to his ( no problem here). But what are the chances that it wont throw a bearing or something because of the little bit of water in the oil ( did not run it after we seen the water in the oil ).
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  2. #2 Re: Chances that the motor is OK??
    If it didn't run you should be ok
  3. #3 Re: Chances that the motor is OK??
    Jul 2011
    Michigan
    we ran it to thaw it out. But no water was in the oil till it thawed completely out.
    SE Level Member Rob97gtp's Avatar
    Jul 2012
    Kansas city
    If there is water in the oil most likely the block is cracked. It doesn't take much to crack a block the passages and the walls of the block are pretty thin.
  5. #5 Re: Chances that the motor is OK??
    could be blown up, running it to thaw it was a bad idea.
    do a compression test before anything else. and a pressure test on the coolant system as well.
  6. #6 Re: Chances that the motor is OK??
    Jul 2011
    Michigan
    Yes but i think any damage done, was done when it froze and expanded.
  7. #7 Re: Chances that the motor is OK??
    heating the block with ice inside still is not a good idea, very hot vs very very cold = cracks.
    if something was to crack while being frozen, it would have been a freeze out plug popping and coolant/water hitting the floor under the car. as thats what they were made to do, hens why its called a freeze out plug.
    the upper intake may have blown as well, that could be where the water got in the oil as well. you can take the tb off and look inside the intake to see if its wet inside. it should be bone dry.
    but before you think of doing a top swap, test those 2 items first. make sure the block is still good.
  8. #8 Re: Chances that the motor is OK??
    Apr 2011
    Vassar, Mi
    This is total misinformation......"freeze plugs" are there because of the casting process during block production. they will almost never save a block from freeze damage. i used to have a picture of the side of a block broken completely out with a freeze plug in the center
    of the broken chunk but i cant find it atm. Core plug - Wikipedia, the free encyclopedia
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
    Aug 2011
    Kenosha
    ^ interesting.. Thanks for sharing, like the guy above, I always thought they were there to protect against cracking. Learn something new everyday.
  10. #10 Re: Chances that the motor is OK??
    there will always be the chance of the block cracking when water freezes in a engine. but ive seen those plugs popped out due to ice more then cracked blocks.
    i look at it this way, if your engine froze, and a plug popped out, good chance the engine is still good. at least the ice had somewhere to expand to.
  1. Blower fan wont turn off with motor running , stops with motor off
    By bosull in forum Introductions/Noob Questions
    Last Post: 04-20-2012, 07:32 PM
  2. Chances of bring this down in price?
    By vicious in forum General Tech Discussion
    Last Post: 06-17-2011, 05:25 PM
  3. i need to stop taking chances in my car... so im going to
    By 2000GTP in forum Off Topic Discussion
    Last Post: 03-18-2009, 11:52 AM
  4. What's the chances?
    By Dave53 in forum Track Sessions and Kills
    Last Post: 03-14-2009, 11:12 PM
  5. what are the chances
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2008, 10:05 AM
