Thread: lights go dim
Results 1 to 4 of 4
  1. #1 lights go dim
    north carolina
    i"m thinking alternator, but thought i'd run this by the guru's on here.my lights
    are going dim at high rpms(5,500 +)they will dim enough to to appear reddish
    looking. as soon as i let off throttle the least little bit they're bright again.i can
    run all the lights and heater on high for as long as i want doesn't kill the battery
    .i guess my next thing will be volt meter and check voltage.just did and it's at
    14.3 volts at idle and 3,000 rev.what am i missing? how can i check the volts
    at high rpm's? scanner? engine runs fine.thanks in advance.
  2. #2 Re: lights go dim
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Voltmeter probe the cig lighter plug.
    1997 Red GTP 182000 miles stock
  3. #3 Re: lights go dim
    St. Louis
    Belt could be slipping at high rpm's as well. How new is the belt and the tensioner?
  4. #4 Re: lights go dim
    north carolina
    belt was put on christmas day, i thought about tensioner ,but belt seems to be tight. i'll double check fordman77,thanks,jimmy
  1. Help REAR TAIL LIGHTS NOT WORKING, BUT BRAKE LIGHTS WORK.
    By shihiran in forum General Tech Discussion
    Last Post: 10-21-2012, 02:35 PM
  2. Shifting Lights , AC Lights, Door Lights All Went Out?? Grand Prix 04
    By Levi Hardin in forum Audio, Security & Visual Electronics
    Last Post: 06-11-2012, 12:49 AM
  3. Dash Lights out and Tail Lights out on Pontiac Grand Prix 2002
    By aaronman in forum General Grand Prix Discussion
    Last Post: 05-09-2012, 08:31 AM
  4. 2001 GTP - Replacement rear tail lights and front head lights
    By zguy in forum General Grand Prix Discussion
    Last Post: 01-09-2012, 06:21 PM
  5. Replies: 0
    Last Post: 12-04-2011, 01:48 AM
