Thread: Electrical problems Need Help Badly
Results 1 to 8 of 8
  1. #1 Electrical problems Need Help Badly
    GT Level Member titanfan12's Avatar
    Jan 2013
    west palm
    Car problems electrical nick - YouTube
    This is a 99 gtp
    this is a video of the problem, well first off the cooling fans wont turn on and the headlights wont turn on, also when you press the horn the hazards turn on.
    Things ive changed are the ignition harness and multi function switch. ive also checked and changed every relay.
  2. #2 Re: Electrical problems Need Help Badly
    check the grounds on the tranny bell housing yet? as well as the battery to body grounds and the terminals?
    the tranny grounds have 2 wires leading to it, the bat neg cable, and two other wires, make sure they are tight and the end loops are still on the wires. these wires tend to break off sometimes.
  3. #3 Re: Electrical problems Need Help Badly
    Jan 2013
    west palm
    the trans bell houseing is checked there all tight and connected
  4. #4 Re: Electrical problems Need Help Badly
    Now check your grounds inside the cabin. I'm aware of one at the base of the steering column..
  5. #5 Re: Electrical problems Need Help Badly
    There's another ground by the driverside headlight too.
  6. #6 Re: Electrical problems Need Help Badly
    Jan 2013
    west palm
    yes ive cleaned them all up and no difference could it be the aftermarket radio?
  7. #7 Re: Electrical problems Need Help Badly
    It shoudln't be...
  8. #8 Re: Electrical problems Need Help Badly
    Jan 2013
    west palm
    well i found the problem.
    thank god because i tore up everything trying to figure this out.
    it was a ground that was right underneath a plastic piece infront of the hood where you pop it open.
    i would have never looked, and the only reason i could find it was because it started to smoke.
    Thanks
  1. Electrical problems?
    By Max in forum General Tech Discussion
    Last Post: 03-23-2012, 03:03 AM
  2. Few Electrical Problems
    By str3etgl0w in forum General Tech Discussion
    Last Post: 08-29-2011, 11:59 PM
  3. Electrical problems....
    By Max PowerX360 in forum General Tech Discussion
    Last Post: 04-02-2010, 11:50 AM
  4. few electrical problems
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2009, 09:49 AM
  5. Electrical Problems 98 GTP
    By KawaFord in forum General Tech Discussion
    Last Post: 07-31-2009, 08:20 AM
