Thread: Polishing a throttle body
Results 1 to 5 of 5
  1. #1 Polishing a throttle body
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    Is it possible to polish a throttle body or sand it down a bit to get the burs and what not out of there without needing a tune? Basically I would be doing this out of boredom and I would like a nice clean throttle body since it's removed and I wouldn't mind cleaning it up a bit.
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: Polishing a throttle body
    I think any type of work done on the bowls of the TB will require a tune. Don't quote me on that never looked into much but I'm sure others will chime in
    04 Comp G.
  3. #3 Re: Polishing a throttle body
    Apr 2013
    Milwaukee
    Ya, thats why I don't want to port it because I know you need a tune for that, I just want to take out the imperfections without opening it up anymore.
  4. #4 Re: Polishing a throttle body
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    You could do that but if u remove the Maf hump it will need a retune or if u open it up any it will need a retune best to just leave it alone
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  5. #5 Re: Polishing a throttle body
    The tiny imperfection dont hurt anything, so its best to leave it be.
  1. Porting and polishing throttle body and LIM
    By thomasd2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2013, 10:44 AM
  2. MAF, IAC & throttle body
    By Nicolecc2 in forum General Tech Discussion
    Last Post: 09-01-2011, 11:12 PM
