Thread: broken pass key 3 module
Results 1 to 10 of 10
  1. #1 broken pass key 3 module
    May 2012
    Cedar Rapids, Iowa
    I was replacing my ignition switch and i was taking the old switch out when the passkey exciter module broke. This is the black ring that goes around the lock cylinder. can i just get a new module or do i have to get a new cylinder.
    I know that i need to get it programmed after installing this. any help is greatly appreciated.
  2. #2 Re: broken pass key 3 module
    Yoga city
    yeah just replace it and have the car securtiy programmed and should be good to go.
  3. #3 Re: broken pass key 3 module
    May 2012
    Cedar Rapids, Iowa
    can i do the relearn myself or does the dealer have to do it
  4. #4 Re: broken pass key 3 module
    Yoga city
    no you will have to have the dealer do that, if you were trying to learn a second key yes. but you cant sicne the ring that reads the keys is broken
  5. #5 Re: broken pass key 3 module
    May 2012
    Cedar Rapids, Iowa
    okay thanks. Do you know about how much the relearn process costs?
  6. #6 Re: broken pass key 3 module
    Jun 2012
    Golden Eagle, IL
    when i broke mine dong my radio, i just put it back together with the used one from Ed Morad and i went to try the relearn, and it didn't need it, it started right up and i never had problems
  7. #7 Re: broken pass key 3 module
    May 2012
    Cedar Rapids, Iowa
    Quote Originally Posted by anarchy View Post
    you got a new cylinder with the passlock 3 and it worked without programming?
  8. #8 Re: broken pass key 3 module
    Jun 2012
    Golden Eagle, IL
    yea i just took apart the cylinder (be careful) and got the passlock ring off and put it on mine and stuck my key in and the car started on the first turn
  9. #9 Re: broken pass key 3 module
    May 2012
    Cedar Rapids, Iowa
    okay thanks thats a load off. I found a cylinder at the junkyard for 65 it should come with the ring right? at least i would think so.
    Thanks again for all the help, im so stressed that this happened. but i guess thats what happens when you dont have a manual and just jump into things lol
  10. #10 Re: broken pass key 3 module
    Jun 2012
    Golden Eagle, IL
    Ed morad on eBay has them for like 45
  1. Old Thread
    By SpeedGrid in forum General Tech Discussion
    Last Post: 09-03-2012, 09:23 PM
  2. Replies: 2
    Last Post: 02-14-2012, 08:47 PM
  3. 97-03 six pass gp's?
    By gpse2000 in forum General Tech Discussion
    Last Post: 07-22-2011, 04:53 PM
  4. Trying to pass emmissions.....help!
    By Cprix02 in forum General Tech Discussion
    Last Post: 05-11-2010, 09:24 AM
  5. my 12 sec pass
    By zexed99gt in forum Track Sessions and Kills
    Last Post: 01-08-2009, 10:48 AM
