Thread: coolant explosion
Results 1 to 10 of 10
  1. #1 coolant explosion
    May 2012
    Cedar Rapids, Iowa
    okay so i just changed the water pump and i was trying to bleed the cooling system. I had the radiator cap off and the wife started the car. The car started. Next thing i know coolant is exploding out of the radiator onto the coils and battery. When it hit the manifold a huge white cloud erupted. I immediately told her to turn it off. I cleaned up the battery and tried my best to dry off the coils. I told her to start the car and it just cranks. The abs, traction control, traction control off, service braking system, and charging system failure battery saver active all came on. I disconnected the battery and tried again. This time the battery is dead.
    Could the coolant have fried the icm?
    Should i get a new battery?
  2. #2 Re: coolant explosion
    The icm has a weatherproof seal on the connector, as do all other connections under the hood. Pull your battery cable again and look for corrosion on the cable at the battery.
  3. #3 Re: coolant explosion
    May 2012
    Cedar Rapids, Iowa
    The cables have no corrosion on them and the battey is clean too. However the battery did die in the process. I had her turn the lights on and they were very dim
  4. #4 Re: coolant explosion
    That's odd... some coolant all over that stuff is quite normal to happen in your type of situation. I've drenched quite a few belts/coils etc and never had a battery go dead like that. Maybe take it in for testing.
  5. #5 Re: coolant explosion
    May 2012
    Cedar Rapids, Iowa
    should i try to jumpstart the car?
  6. #6 Re: coolant explosion
    I don't know. I think it would be a much better check to test the battery and take a third look at the cables. Most guys don't see the corrosion, but then I'm unsure what year you have. If you have 04+ then it's easy to see it.
  7. #7 Re: coolant explosion
    May 2012
    Cedar Rapids, Iowa
    so got a new battery just now and it cranks just fine. It will not start its giving p0030 HO2S heater control circuit, bank one, sensor one.
    This is an oxygen sensor right? why would this prevent the car from starting?
  8. #8 Re: coolant explosion
    St. Louis
    Nope. The 02's shouldn't prevent a startup. When you turn the key on but not try to crank it, do you hear the fuel pump hum for a few seconds?
  9. #9 Re: coolant explosion
    May 2012
    Cedar Rapids, Iowa
    yeah it does. I went out and got it to start after work. I think there was just moisture on the coils preventing spark. also i cleared the code for the 02 sensor and it didnt come back
  10. #10 Re: coolant explosion
    Search on the code so you understand what is going on with it. Usually it takes one or two drive cycles for a code to pop the light on.
  1. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  2. Upper intake explosion.
    By 97gpl36 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-06-2012, 01:24 AM
  3. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  4. AC Delco Explosion
    By Blacknight02GT in forum Off Topic Discussion
    Last Post: 04-04-2009, 08:00 PM
  5. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
