Thread: Coolant recovery tank leak?
Results 1 to 19 of 19
  1. #1 Re: Coolant recovery tank leak?
    I live here. UR LOSN's Avatar
    Rockford, IL
    I'd check all the above^^^^^^^
    good info!
  2. #2 Re: Coolant recovery tank leak?
    Wichita, KS
    ...or, even might check the heater core hoses that attach to the alternator bracket. One local recently had the o-ring under the fitting go out, and was spraying coolant out.
    Could also be your water pump. Check the back side of the pulley to see if its wet, as when these start to leak/fail, they will leak out of the seal on the shaft behind the pulley. As you drive, it flings the coolant everywhere.
    ~F~
  1. suspected coolant leak into oil
    By e56505 in forum General Tech Discussion
    Last Post: 02-16-2009, 03:18 PM
  2. Vehicle problems - won't run, coolant leak
    By boogsey in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-17-2008, 10:17 AM
  3. Coolant leak
    By jdgaetan in forum General Tech Discussion
    Last Post: 05-31-2008, 03:24 AM
  4. Opinions on possible coolant leak
    By Sabrewings in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-25-2008, 11:00 PM
