Thread: Speed Daddy U-Bend Delete Modifications
Results 1 to 20 of 55
  1. #1 Re: Speed Daddy U-Bend Delete Modifications
    Oct 2011
    Toledo, OH
    Yes. Maybe. According to google you should use what's called "tri-mix". I've never used any welders with gas, so I don't know.
    I do know however, from experience, that you can weld stainless-to-stainless and stainless-to-mild exhausts together with regular flux core wire with no gas and it will hold until the welds rust out 3 years later.
    Also I am considering buying some V-Clamp flanges and just welding those to my cuts instead.
    7"
  2. #2 Re: Speed Daddy U-Bend Delete Modifications
    GT Level Member bsharpminor's Avatar
    Mar 2012
    Minnesota
    Quote Originally Posted by industrialfish View Post
    Thanks fish. I'll have to look into tri-gas; hoping it's not to expensive or it may just make sense/cents to pay an exhaust shop after all; not what I wanted to do.
    On another completely unrelated note, what kind of gap are you guys running on your AL 104s?
    Search function doesn't like words with 3 characters or less - "gap"; I know I've read a couple different numbers from folks, can't recall them though.
    I've got pulley in hand and figure while I am tearing things apart I'll change the plugs and t-stat.
  1. u bend delete
    By kking89 in forum General Tech Discussion
    Last Post: 05-18-2011, 06:05 PM
  2. U-Bend Delete
    Last Post: 04-18-2011, 06:02 PM
  3. U Bend Delete & Resonator Delete
    By 9ordohz in forum General Tech Discussion
    Last Post: 10-23-2010, 10:57 AM
  4. U-Bend Delete?
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2010, 12:45 AM
