Quote Originally Posted by gtpeddie View Post
Grind out your struts? That doesn't sound to good.. How hard was the hit, sounds like some uni-body damage might have occurred after the accident. You should never have to grind/cut/force certain parts in thats not good. It also agree it could be a bent rim or tires not properly balanced as stated. But it does kinda sound to me like bad tie rod(s) but you said they were replaced.
I only replaced the tie rod end on the passenger side - not the whole thing.
Is there a way I can tell if my tires are unbalanced? Balancing tires is cheap too, right?
