Thread: intermittent blower on heater
Results 1 to 4 of 4
  1. #1 intermittent blower on heater
    May 2012
    Cedar Rapids, Iowa
    okay so a few weeks back my heater was staying on after i removed the key from the ignition. I then did some research and found the TSB and replaced the blower motor resistor and installed the 330 uf capacitor.
    Now recently when i start the car and turn the heat on, it doesn't matter if its the air or heat, nothing works. Usually after about 10 or 15 minutes of driving the heat will kick on. Sometimes the heat doesn't kick on at all.
    I read somewhere that the ignition switch? or possibly the ignition wiring? any help would be appreciated
    Thanks Chris
  2. #2 Re: intermittent blower on heater
    May 2012
    Cedar Rapids, Iowa
    bump...anybody?
  3. #3 Re: intermittent blower on heater
    New York
    It's the ignition switch! Seems most try the easier route like I did as well of changing the blower motor resistor-didn't work. Most of the power for the accessories including the blower motor speeds and the wipers, goes through the ignition switch module in the column. When you turn the ignition to the on/run position without actually engaging the starter, you will know which accessories are controlled by the ignition module. The module is a small box with contacts in it with the wires coming from the accessories in the column and every time you turn the car on and off, these contacts will spark slightly if the high amperage draw accessories are not turned to the off position before starting and stopping the engine. After you change the ignition module in the column-to prevent another failure-make sure that you turn the blower off before stopping and starting the car. The small sparks cause the contacts to carbonize which eventually prevents the current from going through the contact. Eventually, the blower will stop working. Changing the ignition module swicth cost me $70 from GMpartsdirect.com/rockauto for the Delco and solved the problem-took about 2 hours and probably is not for a novice, but not too bad-work slow and carefully in the column and all will be good. The other option which I did do after I installed the new ignition module is to take the module apart ( a little tricky getting it back together with the springs inside and clean the contacts with light sand paper) and I saved the old GM one as a spare. The GP has 125,000 miles on it now and I did the exchange about 3 years ago-perfect since then. Hope that helps!
  4. #4 Re: intermittent blower on heater
    May 2012
    Cedar Rapids, Iowa
    I found the tutorial for the 97-03. I have a 05 with a dash mounted key. Is this harder to change? is there a tutorial anywhere out there? ive googled for hours and found nothing.
  1. a/c heater blower
    By buschegt in forum General Tech Discussion
    Last Post: 09-25-2012, 05:34 AM
  2. Blower motor intermittent help!! its cold in ak
    By ttjj1410 in forum General Tech Discussion
    Last Post: 12-10-2011, 03:12 AM
  3. Intermittent HVAC blower
    By Doc Banger in forum General Tech Discussion
    Last Post: 01-26-2011, 11:37 AM
  4. Intermittent Blower Motor
    By Securu99 in forum General Tech Discussion
    Last Post: 06-20-2010, 12:21 PM
  5. Heater Blower
    By stratojet in forum General Tech Discussion
    Last Post: 03-22-2009, 09:58 PM
