Thread: Humming sound while turning
Results 1 to 7 of 7
  1. #1 Humming sound while turning
    Sep 2011
    Syracuse, Utah, United States
    My car just recently started to make an odd humming sound when I turn (I just replaced my power steering system in August) so I don't think that could be the problem...can I get some of your guys thoughts?
  2. #2 Re: Humming sound while turning
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    Which ever way you are turning, it is the opposite side wheel bearing. Is it the front of back?
    97 Bonneville SE Not so much a 97 anymore
  3. #3 Re: Humming sound while turning
    Yoga city
    Is it power steering hum? Could be low fluid
  4. #4 Re: Humming sound while turning
    GTP Level Member buickman104's Avatar
    NYC
    Probably low on power steering fluid or power steering pump is on its way out.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  5. #5 Re: Humming sound while turning
    Sep 2011
    It sucks that the way they built my Grand Prix I can't even find where to put the fluid...found the lines, but that's it
  6. #6 Re: Humming sound while turning
    north carolina
    go to the pass. side of the car, look at the alternator, then lean over and try to see the ground
    from under the hood ,there's the power steering pump. seriously it' its hidden behind the engine,
    you'll need a long funnel to add fluid.,jimmy
  7. #7 Re: Humming sound while turning
    heres a pic, its the same s/c or N/A
    p/s pump is on the far left
  1. Sorta sounds like a tearing sound when front wheels turning?
    By spider4 in forum General Tech Discussion
    Last Post: 12-11-2011, 01:00 PM
  2. not sure, could be hub? humming sound
    By kyle91 in forum Brakes/Suspension/Chassis
    Last Post: 07-22-2011, 10:36 AM
  3. humming sound while driving
    By foursixer in forum Brakes/Suspension/Chassis
    Last Post: 02-18-2010, 03:42 PM
  4. humming sound
    By gearheadamongus in forum Audio, Security & Visual Electronics
    Last Post: 07-03-2009, 06:10 PM
  5. popping sound when turning...?
    By fst in forum Brakes/Suspension/Chassis
    Last Post: 05-06-2008, 07:49 AM
