Thread: 1998 Buick Regal Problems
Results 1 to 20 of 25
MidnightBlue 1998 Buick Regal Problems 12-12-2012, 01:01 AM
asite57 Re: 1998 Buick Regal Problems 12-12-2012, 01:21 AM
BillBoost37 Re: 1998 Buick Regal Problems 12-12-2012, 06:31 AM
MidnightBlue Re: 1998 Buick Regal Problems 12-12-2012, 09:26 AM
Scottydoggs Re: 1998 Buick Regal Problems 12-12-2012, 10:38 AM
BillBoost37 Re: 1998 Buick Regal Problems 12-12-2012, 09:29 AM
MidnightBlue Re: 1998 Buick Regal Problems 12-12-2012, 10:29 AM
MidnightBlue Re: 1998 Buick Regal Problems 12-12-2012, 12:05 PM
Scottydoggs Re: 1998 Buick Regal Problems 12-12-2012, 12:14 PM
MidnightBlue Re: 1998 Buick Regal Problems 12-12-2012, 12:39 PM
Scottydoggs Re: 1998 Buick Regal Problems 12-12-2012, 12:56 PM
BillBoost37 Re: 1998 Buick Regal Problems 12-12-2012, 12:58 PM
MidnightBlue Re: 1998 Buick Regal Problems 12-12-2012, 01:04 PM
BillBoost37 Re: 1998 Buick Regal Problems 12-12-2012, 01:05 PM
Scottydoggs Re: 1998 Buick Regal Problems 12-12-2012, 01:06 PM
MidnightBlue Re: 1998 Buick Regal Problems 12-12-2012, 01:07 PM
Scottydoggs Re: 1998 Buick Regal Problems 12-12-2012, 01:18 PM
MidnightBlue Re: 1998 Buick Regal Problems 12-12-2012, 02:05 PM
BillBoost37 Re: 1998 Buick Regal Problems 12-12-2012, 02:06 PM
MidnightBlue Re: 1998 Buick Regal Problems 12-12-2012, 02:15 PM
BillBoost37 Re: 1998 Buick Regal Problems 12-12-2012, 02:23 PM
Scottydoggs Re: 1998 Buick Regal Problems 12-12-2012, 02:40 PM
MidnightBlue Re: 1998 Buick Regal Problems 12-13-2012, 05:31 PM
BillBoost37 Re: 1998 Buick Regal Problems 12-14-2012, 08:30 AM
MidnightBlue Re: 1998 Buick Regal Problems 12-14-2012, 01:35 PM
  1. #1 1998 Buick Regal Problems
    Banned
    Sioux Falls, SD
    So today i went out started my car started just fine, it was about 10 degrees here and i havent drove my car for about a week. I go inside to finsih getting ready and i come out and my car is no longer running. I can crank it over. there is nothing. I havent had a chance to try and jump it cause i had to be at t jury trial. Could the alternator or battery cause this?
    If it is the battery here are my options
    If its the alternator ill just have mine rebuilt
  2. #2 Re: 1998 Buick Regal Problems
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    it could be any number of things really first id try jumping it if it runs go to your local parts store and have them test you battery and alt. if i doesnt check for fuel, if you have a way to check fuel pressure thatd be really helpful, my first guess would be a fueling problem but try the easy things first that only takes about 10min
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  3. #3 Re: 1998 Buick Regal Problems
    If it cranks, then what is the purpose of adding voltage by jumping? You should be able to tell if the battery is nearly dead by a super slow crank or no crank.
    Are you missing fuel or spark?
  4. #4 Re: 1998 Buick Regal Problems
    Banned
    Sioux Falls, SD
    I ment to say i cant crank it over, and i had fuel pressure and spark cause it was running before i went inside
  5. #5 Re: 1998 Buick Regal Problems
    Quote Originally Posted by MidnightBlue View Post
    you cant just assume you have fuel and spark. the car wont run. these are your first 2 checks if the engine cranks but wont start.
  6. #6 Re: 1998 Buick Regal Problems
    Well then...I'm sure checking that the battery cables are snug is first on your list.
  7. #7 Re: 1998 Buick Regal Problems
    Banned
    Sioux Falls, SD
    Did that already, and cleaned them
  8. #8 Re: 1998 Buick Regal Problems
    Banned
    Sioux Falls, SD
    I jumped it and it ran just fine, as soon as i take the jumper cables off it dies like 2 min later so its gotta be either my battery or alternator
  9. #9 Re: 1998 Buick Regal Problems
    test your battery. test it car off, should be 12 volts or higher. then test the battery when its running it should be 13 volts to 14 volts, give it a little gas to see if the volts go up if they are still at 12 or not much higher then when running. low volts running is a bad alt.
    some parts stores also have a load tester to test the battery, they can also test your alternator if you take it off and bring it in. same as the battery. you need to bring it inside the store.
    and as far as rebuilding your old alt, they are usually cheaper. ive gone that route in the past as well. its nice when they have one ready to go. but have gone back in as little as a hour to pick them up, and they look like new too.
  10. #10 Re: 1998 Buick Regal Problems
    Banned
    Sioux Falls, SD
    I have them both pulled out, im waiting for a ride to get to oreillys to test them both out, right now the best option is the a interstate battery MT-78 for $93 with 875 CA and 700 CCA and if my alternator is bad a place here in town rebuilds them and have one ready for $88 dollars exchange.
  11. #11 Re: 1998 Buick Regal Problems
    that battery should do just fine. just make sure the terminals are on the right sides, aka match your old one.
    and your re builder cost about the same as my local guy, 80 to 90 is the norm, can go up or down depending on the car of course.
  12. #12 Re: 1998 Buick Regal Problems
    I'm getting batteries for about $60 new fwiw with discount codes.
  13. #13 Re: 1998 Buick Regal Problems
    Banned
    Sioux Falls, SD
    Please share bill?
  14. #14 Re: 1998 Buick Regal Problems
    Search for advance auto discount codes. or whatever parts store is in your area.
  15. #15 Re: 1998 Buick Regal Problems
    if you have a advance auto near by. you go on line, enter discount code, buy it on line, and pick it up locally. they give this months code at the top of every page. top right side.
  16. #16 Re: 1998 Buick Regal Problems
    Banned
    Sioux Falls, SD
    I called 1 other place and they have a AC-Delco battery with 800 CCA for $90 which should i go with?
  17. #17 Re: 1998 Buick Regal Problems
    if its a gs, it calls for the higher cca's 900 would be dandy.
    when buying a battery if you live in a cold area, you always want the highest CCA'S you can get. in my last truck i had 2, 1,000 CCA battery's hooked up, helped a ton with snow plowing. with one single stock battery, when i worked the plow the volt gauge would get pinned to the low side bottom, dim the lights. installed the two 1000 cca's and the gauge would flick 1/2 way down, and then climb back up a bit. and the plow moved much faster.
  18. #18 Re: 1998 Buick Regal Problems
    Banned
    Sioux Falls, SD
    so should i go with the interstate or acd?
  19. #19 Re: 1998 Buick Regal Problems
    Which do you want?
  20. #20 Re: 1998 Buick Regal Problems
    Banned
    Sioux Falls, SD
    im asking which if better in your guys opinion
  1. 2007 Grand Prix into a 1998 Buick Regal
    By MidnightBlue in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-26-2012, 09:05 AM
  2. 1998 Buick Regal Project
    By MidnightBlue in forum Members Rides
    Last Post: 08-01-2012, 12:33 PM
  3. FS: 1998 Buick Regal GS
    By SnowFlake in forum For Sale - Vehicles
    Last Post: 06-13-2012, 11:01 AM
  4. 1998 Grand Prix 3100 engine swap to a 2001 Buick Regal 3800
    By glisarjustin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-30-2012, 09:16 AM
  5. 1998 Buick Regal Gs ANNOYING SQUEEK
    By chi_town in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-26-2010, 05:38 PM
