There is a mini-lamp for the radio time display which burns out. The dash panel and radio have to be removed to replace it. The part # is 16208443 available at the dealer. Cost approximately $8.00. Once the radio is out you remove the face of it and the top panel and the bulb is located right behind the LCD panel. Should twist out of the circuit board (be careful as this can be brittle). Then just pop the new one in and test it BEFORE you put the entire dash back together.
