Thread: Heater blowing weird...
Results 1 to 4 of 4
  1. #1 Heater blowing weird...
    SE Level Member dabears's Avatar
    Nov 2012
    illinois
    Hey guys I got an 03 prix and the heater blows hot but recently has been acting funny, it will blow like it's on 5 than blow likes its on 3 and will fluctuate between the two, before the heat would only blow if you put the switch to the 3 setting, it wouldn't work on 1 or 2 but 3,4,an 5 did work fine so I didn't care till now...i was thinking of just replacing the the whole unit but if anyone else has had problems with this plz chime in, I'd hate to buy a new dash unit and it not be the problem, oh and the clock display doesn't work either. Thanks guys
  2. #2 Re: Heater blowing weird...
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    Sounds like the blower resistor is going out it is under the dash passanger side right beside the blower motor
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  3. #3 Re: Heater blowing weird...
    St. Louis
    There is a mini-lamp for the radio time display which burns out. The dash panel and radio have to be removed to replace it. The part # is 16208443 available at the dealer. Cost approximately $8.00. Once the radio is out you remove the face of it and the top panel and the bulb is located right behind the LCD panel. Should twist out of the circuit board (be careful as this can be brittle). Then just pop the new one in and test it BEFORE you put the entire dash back together.
  4. #4 Re: Heater blowing weird...
    Nov 2012
    illinois
    thanks guys i shoulda did some searchin b4 i posted cause it seems like a common prob, as for the radio light thanks! it kinda sucks having to guess what radio station im tuning to
  1. Heater blowing cold air
    By lawadm1 in forum General Grand Prix Discussion
    Last Post: 11-06-2012, 07:35 AM
  2. 98 GTP heater not blowing hot on drivers side any help?
    By transbldr in forum Introductions/Noob Questions
    Last Post: 01-31-2012, 06:24 PM
  3. Heater not blowing hot air on passenger side
    By grausj1 in forum General Tech Discussion
    Last Post: 10-31-2011, 08:15 PM
  4. heater not blowing hot air
    By mfowler12 in forum General Tech Discussion
    Last Post: 12-09-2010, 11:19 PM
  5. Heater stopped blowing
    By monsterjam5000 in forum General Tech Discussion
    Last Post: 07-25-2010, 11:02 AM
