Thread: Service traction control soon light and abs
Results 1 to 12 of 12
  1. #1 Service traction control soon light and abs
    Nov 2012
    elkmont al
    I have a 07 grand prix gt.The service abs and tc light stay on all the time. has two new hub asimblies and speed sensors on it. The wiring appears to be ok does anybody have a clue what it might be. I need help cant keep spending 90 to have the code read.
  2. #2 Re: Service traction control soon light and abs
    Mar 2012
    Minnesota
    90 bucks for a code? dude, go to Autozone/O'reillys/advanced/pepboys/napa and its free to read.
  3. #3 Re: Service traction control soon light and abs
    Nov 2012
    elkmont al
    They dont have the reader to do it at the stores were i live.
  4. #4 Re: Service traction control soon light and abs
    abs scan cost money almost always, its a different kind of scanner. same as a air bag scanner.
    any way the last time you had it scanned? what codes did you get? and what did you do so far?
    what you can do is jack up each wheel, leave the lugs tight, grab the top of the tire, and push and pull firmly, your looking to feel play in the wheel. if its loose feeling, your hub is bad.
    you can also remove the plugs from the hubs, clean them with electrical parts cleaner and then dab some de electrical grease on the plug, and then work the plug off and on a few times to work the grease in.
  5. #5 Re: Service traction control soon light and abs
    Our cars are 4 wheel abs, maybe its one of the 2 you havent replaced.
    Do you have the codes from when you got it scanned before and you've been replacing the wrong ones this whole time?
  6. #6 Re: Service traction control soon light and abs
    GT Level Member GMCustomerService's Avatar
    Michigan
    adamsz28,
    I agree with the others, would you please provide the codes.
    Feel free to PM me if you prefer.
    Louis
    GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
  7. #7 Re: Service traction control soon light and abs
    Nov 2012
    elkmont al
    it was the code for the front passenger side wheel hub
  8. #8 Re: Service traction control soon light and abs
    Mar 2012
    Minnesota
    sorry, didnt know, good to know
  9. #9 Re: Service traction control soon light and abs
    tried any of those suggestions up top there yet?
    and my guess is the pass front hub has been replaced?
  10. #10 Re: Service traction control soon light and abs
    Nov 2012
    elkmont al
    yes both have been replaced
  11. #11 Re: Service traction control soon light and abs
    test the rear hubs? we do have 4 wheel abs. and the back wires/plugs?
  12. #12 Re: Service traction control soon light and abs
    Nov 2012
    elkmont al
    the back is all good
  1. Replies: 5
    Last Post: 02-01-2017, 09:35 PM
  2. Traction Control/Service ABS
    By stealthee in forum 04+ Specifics
    Last Post: 07-28-2011, 10:19 PM
  3. 05 GT ABS & Traction Control Service Light w/ strange noises
    By zx7r4u2nv in forum General Tech Discussion
    Last Post: 06-02-2011, 09:37 AM
  4. Service ABS, traction control, variable steering
    By Lionel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2011, 08:09 PM
  5. 04 GTP Service ABS/ TRaction control
    By busagtp in forum General Tech Discussion
    Last Post: 09-07-2009, 12:03 PM
