Thread: Rear Window Defroster - Fuse/Rely Location
Results 1 to 2 of 2
  1. #1 Rear Window Defroster - Fuse/Rely Location
    SE Level Member 99XC600's Avatar
    Apr 2012
    Wilbraham MA
    The rear window defroster went out this week. When I press the button, the indicator lights up but I don't hear the click of the relay that I normally did. I consulted the manual to locate the fuse relay and it says it's under the panel on the left hand side of the dash.
    No problem, I figure I would pull the module and start doing some voltage checks. Well, I pulled the panel off and found the upper portion of the diagram and all of the fuses line up with what's shown. However the bottom part of the diagram shows another bank of fuses and relays. However in my car there is a wiring block where the relays should be. There appears to be single 8mm nut holding it down but I didn't want to pull it off for fear of messing with something I shouldn't.
    2004 Ivory White Pontiac Grand Prix GT1 - Bone Stock and my 80 mile daily driver.
  2. #2 Re: Rear Window Defroster - Fuse/Rely Location
    Apr 2012
    Wilbraham MA
    Anyone?
  1. Ac, Ac max power and rear defroster indicator lights are blinking
    By gto421 in forum General Tech Discussion
    Last Post: 09-21-2012, 12:43 AM
  2. '88-'96 Grand Prix fuse box location
    By Condor120 in forum General Tech Discussion
    Last Post: 08-26-2010, 06:03 PM
  3. 04 rear window defroster
    By mikev69 in forum General Tech Discussion
    Last Post: 01-23-2010, 08:08 PM
  4. 2002 GTP Rear Defroster Problems
    By irex511 in forum General Tech Discussion
    Last Post: 01-21-2010, 05:54 PM
  5. 07 Grand Prix - Rear defroster messes up radio
    By thevolkp in forum General Tech Discussion
    Last Post: 10-23-2009, 10:28 AM
