Thread: Dumb question......
Results 41 to 60 of 61
  1. #1 Re: Dumb question......
    GTX Level Member HVACgtp's Avatar
    Oct 2012
    South Jersey
    Why do you want to leave that tubing? Just asking. Get rid of that corrugated tubing, it's a restriction In air flow!
    2001 Silver GT; K&N Intake, 2.5in catback to flowmaster 40's, custom tune, led tails drag wheels and halos......SOLD
    2004 Silver GTP - its got some stuff http://www.grandprixforums.net/deja-vu-71112.html
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    Quote Originally Posted by HVACgtp View Post
    Cuz it looks 10x cleaner? And it still has the iat bung...
    Nov 2012
    MN
    And regardless of air restriction, it will flow much better than stock air box.
  4. #4 Re: Dumb question......
    So did anyone measure the pressure drop across the stock airbox yet?
  5. #5 Re: Dumb question......
    Oct 2012
    South Jersey
    Cleaner? I think it looks worse lol
    Nov 2012
    MN
    U think who ha what?
  7. #7 Re: Dumb question......
    Oct 2012
    South Jersey
    I asked why you left the corrugated tuning, you said it looks 10x cleaner, I said cleaner? Inthink it looks worse than building your own
  8. #8 Re: Dumb question......
    Pennsylvania
    Quote Originally Posted by comatoast View Post
    PCV bung
  9. #9 Re: Dumb question......
    Nov 2012
    MN
    Quote Originally Posted by SlowNA06 View Post
    PCV bung
    Sorry
  10. #10 Re: Dumb question......
    Oct 2012
    South Jersey
    The rubber coupling I used to attach the maf to the throttle body I used a drill bit, drilled a hole into the side if it and popped it right in, looks clean as couldbe
  11. #11 Re: Dumb question......
    Nov 2012
    MN
    not trying to be a dick.. trust me.. I like your car and your a good guy..... I like my **** clean.. maybe your version and mine are different.. To me.. Your intake looks hacked... Mine looks stock w a different filter.. Your MIGHT flow more but Im guessing not much, but it still looks cheap like you use fittings from the plumbing department at home depot
  12. #12 Re: Dumb question......
    Pennsylvania
    You better be. Bung. Bung. Bung. Gosh that's a weird word. Bung.
  13. #13 Re: Dumb question......
    Oct 2012
    South Jersey
    Actually I did use a Fernco coupling from my shop, reason being the rubber matrial use to make these due to pressure ratings is a lot thicker than the cheap **** you buy from an auto parts store, so that it will support the filter and hold up more, and to each his own I guess. And if you want your stuff clean, don't hack it by just putting a filter on the end, spend the money and buy an intake, then it will look clean
  14. #14 Re: Dumb question......
    Oct 2012
    South Jersey
    This is the only DIY intake that I think is the best looking, sure I can do this. But it's not needed, and it's a lot better looking than stock with a filter http://www.grandprixforums.net/do-yo...ics-53317.html
  15. #15 Re: Dumb question......
    Nov 2012
    MN
    thats nice... No offense man, Like I said I needed a quick fix so I got the 6" on the stock intake... Ill take a few pics... Not as clean as I'd like it, but at least got rid of the stock air box
  16. #16 Re: Dumb question......
    Oct 2012
    South Jersey
    No offense taken, like I said to each his own. I had the same thing you did, and I hated it. I never even wanted to open my hood. But I like this a lot better, if I bought a 45 and another coupler it would be the same thing, but the least distance and less bends makes for better air flow. My job is moving air and making it hot or cold, so air flow is kinda my thing lol. If I still had my original air box I would use my meter and test cfm but I threw it out like a dumb arse lol
  17. #17 Re: Dumb question......
    Nov 2012
    MN
  18. #18 Re: Dumb question......
    Pennsylvania
    Take out the other half of your airbox homeboy.
    Nov 2012
    MN
    Why is that ? Wanksta
  20. #20 Re: Dumb question......
    new britain, ct
    because the ribs inside the duct are restrictive.
    although you probably arent really flowing too much air to have a restriction.
    07 Black GXP.
  1. Might be a dumb question, but...
    By SteveCZ28 in forum General Tech Discussion
    Last Post: 02-19-2011, 11:06 AM
  2. Dumb Question?
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-26-2011, 06:59 PM
  3. Dumb question of the day
    By johnb62 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-06-2010, 12:13 AM
  4. dumb oil question
    By J06GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2010, 12:27 AM
  5. Dumb question (Oil)
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2008, 12:10 PM
