Just bought one last night, in all honesty I like it better than my old kn lol
Over oiled filter + external MAF sensor = fun times.
Dry flow FTW.
I agree with all of you guys. KnN way over oiled. , but isn't the spectre oiled as well? I would buy a spectre right off the shelf but like posted above, with the MAF the way it is and then u slap on a cone filter right on it, aren't all oiled filters going to soak the MAF? I would get a dry filter if we had em.
Anyone ever check the MAF or clean it out when running an oiled filter?
I think spectre has a slight coating of oil, but I don't really know. I run a AEM dryflow filter.
The one I just bought last night has no oil on it
AEM FILTERS ARE ON TEH SUPER SALE AGAIN.
Buy one, now, its that good of the deal.
Aem 9"x4" Conical Dryflow Air Filter Element 21 2059DK | eBay
Don't have a pn, but it was the 40 dollar spectre filter. I believe it's a 9 inch come, fits 3-3.5-4 inch holes. I just used 4 inch and tightened it down. And just pick up a rubber coupling for the maf to tie into the throttle body. You will see everything on my ride page
The MAF and tb are 4 inch openings? Didn't look that big when I had the tb off
Use a rubber coupling to reduce the size.Quote:
If you were to buy that AEM filter you need a 4-3 I believe then tubing from the MAF to the TB.
The spectre has rubber inserts so you get to choose which size you want...IIRC there is a 4", 3.5", and a 3" reducer.
Exactly, the filter I got came with 4-3.5-3 reducers on the filter
Thought I mentioned that lol
I like it so far, prob got the same one, I got red :-)
Well here's my issue as the intake is tore apart. I don't wanna remove the stock back half of the box cuz I wanna keep the PCM in there. Would a 6" be fine? Only reason I'm asking is because I wanna leave the stock intake tube ( the one from the tb to the MAF ) intact. And I can't fit a 9".
