Thread: Whistle..?
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Whistle..?
    Dec 2012
    Des Moines, IA
    Ok, guys...my N/A gt started whistling this morning between 1/3 to full throttle. Its sounds cool, but worries me at the same time. I was trying to follow all of your posts in this thread, but got lost. My car, however, doesnt whistle at idle or cruise speeds that I can hear. Would this be a exhaust gasket leak?
    Note: it was about 20 degrees (F) out this morning.
    ...A gear-head in my own way...
  2. #22 Re: Whistle..?
    Dec 2012
    Des Moines, IA
    Anyone have an idea of why mine is making this whistle too?
  3. #23 Re: Whistle..?
    Pennsylvania, USA
    Try to determine where it's coming from in the engine bay, once we know a general location we can rule stuff out, too many possibilities otherwise.
  4. #24 Re: Whistle..?
    Dec 2012
    Des Moines, IA
    I tried revving the motor and listening to the sound with the hood open today. It sounds like it coming from the passenger side. I hear it more when I'm inside the car pushing the throttle with my foot.
  5. #25 Re: Whistle..?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by SpeedGrid View Post
    I am having this problem as well. Happens usually when the car is hot. I popped the hood and it sounds like its coming from the supercharger. The supercharger is relatively new as it was replaced a couple months after owning the car under warranty so the pcv valve is new as well. Did you figure out what is causing the problem? I have a 2004 grand prix gtp.
    The problem comes and goes once or twice a month and its really annoying. I checked for vacuum leaks and I dont seem to have any.
    If I recall correctly, it's a leak between the supercharger and whatever it's called that it's bolted to. Upper manifold?
    7"
  6. #26 Re: Whistle..?
    St. Louis
    The SC is the upper manifold. That would be the LIM it's bolted to.
  7. #27 Re: Whistle..?
    Jul 2012
    Clayton,NC
    My gen3 makes a similar noise as the op's just not as loud. I know it's not a vac leak or an exhaust leak and it sounds like it's coming from the snout. I think it's bearings in the blower/snout whatever. But until its gets worse I'm like screw it.
    98 gtp- cammed intercooled slowness
  8. #28 Re: Whistle..?
    Dec 2008
    Lawndale, CA
    My brothers 03 gen 3 just started doing this.
  1. Weird whistle/rattle when in low revs/idling
    By nik12937 in forum General Tech Discussion
    Last Post: 06-10-2012, 10:33 PM
  2. whistle
    By iluvbst in forum General Tech Discussion
    Last Post: 12-24-2010, 10:53 AM
  3. Whistle in engine bay over 3,000rpm
    By SuperSport in forum General Tech Discussion
    Last Post: 06-05-2010, 08:03 PM
  4. high-pitched whistle and bouncing idle
    By CSteen85 in forum General Tech Discussion
    Last Post: 04-28-2010, 07:58 AM
  5. "The whistle's go WOO WOO" on my 04 GT1, what's wrong with it? (video)
    By iroczkidtpi in forum General Tech Discussion
    Last Post: 06-25-2009, 04:44 PM
