Thread: Fuel Injector Cleaning
Results 1 to 7 of 7
  1. #1 Fuel Injector Cleaning
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Sent the injectors on the 01 GT out to be cleaned, here is the report showing the before/after flow bench results. Before on the left after on the right.
    Only 1 of the 6 injectors was performing at spec, the other 5 were variously degrees of plugged. The "after" test shows them all performing identically at spec. Ironically the injectors on the 98 showed better "before" results than these did with about the same mileage (153K).
    Hmm where did you send them out too? And how much?
    04 Comp G.
  3. #3 Re: Fuel Injector Cleaning
    Dec 2008
    ****'s Creek
    I sent them to Mr. Injector in Idaho. He charges $16 per injector plus return shipping. Service includes flow bench testing on arrival, ultrasonic cleaning, electrical test, replaces internal sock filter, both O-rings and the plastic pintle on the nozzle end. Re-checks flow on the bench before shipping back. Sent them out USPS priority on a Monday and had them back on Saturday. Bill turns the injectors around in 1 day but it's the shipping that kills the time.
    He also sells DIY rebuild kits on FleaBay but you don't get the ultrasonic cleaning. I can tell you that the nozzles looked a lot cleaner when they came back, no more varnish on the ends.
  4. #4 Re: Fuel Injector Cleaning
    Sep 2011
    Copperas Cove, TEXAS
    Damn, so for a little over $100, compared to new ones from the parts store is a deal. Thanks for posting this.
  5. #5 Re: Fuel Injector Cleaning
    Dec 2008
    ****'s Creek
    They basically are new when they come back. A little oil on the O-rings and ready to install.
    I live here. DirtDog's Avatar
    Jun 2012
    Would u say this would be good to do to a car with only 50xxx miles on the fuel injectors?
    Sent from my pager using Morse code. ... .. ... ....
  7. #7 Re: Fuel Injector Cleaning
    Dec 2008
    ****'s Creek
    I would say only if you are having drivability issues. I am still trying to determine what the metrics are...for example, the worst one was at 51cc against the clean standard of 55cc. So that's only a 7.5% reduction in flow, and I'm not sure in the injector world if that's considered nominal or a horrendous clog. Although having them all balanced at the same flow rate helps the engine run smoother.
    I had the injectors out for a LIM job, and had downtime with the car, so decided since I was going through the engine I would get this done one time.
  1. fuel injector resistance
    By Viprklr in forum 5.3L V8 (LS4)
    Last Post: 06-17-2012, 11:48 AM
  2. Fuel Injector O-Rings
    By bobabooie in forum General Tech Discussion
    Last Post: 04-07-2011, 07:08 AM
  3. Fuel injector seating
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:42 AM
  4. Injector cleaning, yes or no?
    By Sabrewings in forum General Tech Discussion
    Last Post: 10-20-2008, 12:17 AM
  5. Fuel Injector O-ring ????
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-24-2008, 05:16 PM
