Thread: New brake problem.... Help!!
Results 1 to 3 of 3
apierce1289 New brake problem.... Help!! 12-03-2012, 02:40 PM
BillBoost37 Re: New brake problem....... 12-03-2012, 02:48 PM
apierce1289 Can I use some lube to help... 12-03-2012, 03:00 PM
  1. #1 New brake problem.... Help!!
    GTP Level Member apierce1289's Avatar
    United States
    I put new brake pads and rotors on my 2002 Grand Prix last night ( all 4 tires ). I'm having trouble with the front driver side brakes. There's tons of brake dust and a high pitched squealing noise but it's not very loud. I bought the Wearever ceramic brake pads with new hardware (platinum pads). All of the other wheels are perfectly fine it's just the drivers side :-( I'm going to take it apart in a couple of days and I need some tips and help so that I can resolve the issue. Also how would you advise that I get the front brake pads into the slots where the little metal brackets go because they were very difficult to get in the first time.
    Sent from my DROID RAZR using Xparent Red Tapatalk 2
    Gremlins always seem to show up in pairs, or groups of three with our cars...
  2. #2 Re: New brake problem.... Help!!
    Synthetic caliper lube is good. Ensure when you take it apart that you pull the pins, clean then and lube them. As for the noise, likely it's the new hardware. Ensure it's fully seated, it can be a pain to get them clipped in and centered to ensure they aren't rubbing.
    United States
    Can I use some lube to help the brake pads seat in the brackets properly. They likely are rubbing cause the drivers side is covered in brake dust as wear the other wheels have only a little from the old brakes. Drivers side looks like someone powder coated it :-(
  1. need help on a intermediate brake problem!
    By dhdolphns in forum Brakes/Suspension/Chassis
    Last Post: 09-17-2012, 06:29 AM
  2. Problem with rear brake.
    By WolvesSoulZ in forum Brakes/Suspension/Chassis
    Last Post: 07-15-2012, 12:55 PM
  3. Problem with brake safety switch
    By Jordanmccarty in forum General Tech Discussion
    Last Post: 03-03-2012, 10:38 AM
  4. 04 Brake Problem
    By noriejj in forum Brakes/Suspension/Chassis
    Last Post: 01-19-2012, 04:04 PM
  5. Antilock Brake Problem
    By $03gp/gt$ in forum Brakes/Suspension/Chassis
    Last Post: 03-05-2009, 05:33 PM
