Well, the idler pulley for the supercharger belt seized destroying the pulley and eating the belt. In turn, it out it took out the accessory drive belt with it. I replaced just the accessory belt to get it home. A week later just driving down the street and the engine shuts off out of the blue. No check engine light, no sputtering, just off. Won't restart. No spark, no fuel injection. Has fuel pressure, pump runs the prime cycle. Replaced ignition module with known good unit. No start. Switched computers with known good unit. No start. I pull the crank pulley and sure enough there is a strip of belt wrapped up around the triggers and the crank sensor has physical from the belt. Ah-ha! Replaced the crank sensor. Still no start. All wiring appears intact & unharmed.
What am I missing here?
Car is 00 GTP.
