Thread: 2001 GP GT A/C problem
Results 1 to 7 of 7
  1. #1 2001 GP GT A/C problem
    Georgia
    Hi, got an a/c problem that maybe someone might have a solution for. Wife hadn't used the a/c for a week since it was cool, I took the car last weekend and the a/c was blowing warm air. Took it to my neighbors to put the gauges on it and check the freon and pressure levels, all was ok and it was full of freon. Compressor runs fine, no noises or rattling. I checked the climate control switch and it seemed to be working alright. The actuator that changes where the air comes out, floor, dash or defrost was working. I am thinking that there might be a blockage between the evaporator and the blower but I'm not sure. Anyone have any suggestions? Thanks
  2. #2 Re: 2001 GP GT A/C problem
    Sounds like a blend door problem
  3. #3 Re: 2001 GP GT A/C problem
    Georgia
    Sounds like a pain!! Thats what I figured, I dont think this is something I want to get into pulling the dash apart. I bought an inspection probe camera, thought I might be able to look down one of the vents to see if I could see anything blocking the door. Thanks
  4. #4 Re: 2001 GP GT A/C problem
    Blend doors arent super bad. You shouldnt have to tear the whole dash apart.
  5. #5 Re: 2001 GP GT A/C problem
    not really that hard to do, the driver side is tight tho. pass side is easy as pie. the how to. http://www.grandprixforums.net/blend...ent-21941.html
    is one side cold and the other warm? if so you only need to change the one thats acting up.
  6. #6 Re: 2001 GP GT A/C problem
    Georgia
    Both sides are warm. Is the blend door actuated by vacuum?
  7. #7 Re: 2001 GP GT A/C problem
    no they are power by a small electric motor inside that part thats broken. sometimes they just freek out and quit working, or inside a gear breaks or strips.
    if you go a head and take the old one off, you can turn the knob by hand, and put he actuator back on to hold it in place. pass side is easy place to play with it. and get a feel for what you have to do on the drivers side semi blind.
    you can also take it off the hvac box, leave it plugged in, and turn the heat up, and then down to watch it move or not, it only moves a small amount too, 1/2 inch each way.
  1. 2001 grand prix gt wireing problem
    By nascartech in forum General Tech Discussion
    Last Post: 10-08-2010, 10:20 PM
  2. 2001 grand prix problem list
    By 01gt ryan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2010, 01:40 AM
  3. MAF problem 2001 Grand Prix GT V6
    By hurricanejt in forum General Tech Discussion
    Last Post: 07-13-2010, 11:04 AM
  4. 2001 GP SE 3.1L Cooling problem?
    By Bottoni70 in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-28-2010, 08:49 PM
  5. 2001 GTP Power Seat Problem
    By dmontgom in forum General Tech Discussion
    Last Post: 04-15-2010, 06:04 PM
