Thread: pcm done ?
Results 1 to 10 of 10
  1. #1 pcm done ?
    Nov 2012
    pa
    so after my buddy tune my gtp i couldnt read codes and the scanner came up check wires or fuses i checks all the wires and fuses nothing wrong could my pcm be hitting the bucket ??? or is it something else ?
  2. #2 pcm hitting the bucket?
    Nov 2012
    pa
  3. #3 Re: pcm hitting the bucket?
    Texas
    Or your buddy doesn't know how to tune and messed up your PCM?
    85 Corvette
    01 TA
    03 Z06
    I live here. DirtDog's Avatar
    Jun 2012
    Do u have two accounts??? Same thread exact same wording?? Posted 6 minutes apart...hmmmmm
    Sent from my pager using Morse code. ... .. ... ....
  5. #5 Re: pcm hitting the bucket?
    Nov 2012
    pa
    so i guees swap it out and see if another pcm works cuz hes tuner wont read me nomore nothing and i was thinking it was fault but didnt want to hear him B+++h about it
  6. #6 Re: pcm done ?
    Nov 2012
    pa
    sorry getting use to this site i seen the general talk so yeah my fault bud
  7. #7 Re: pcm done ?
    Have you checked the cig ligher fuse yet.
    If not, do it and see if its blown.
  8. #8 Re: pcm done ?
    Nov 2012
    pa
    all fuses were checked non blown so im lost because im build l36 bottom l67 top i blew my bottom end racing a genesis i won till she went and spun a bearing sad face lol but i have a xp cammed l36 im putting my 3.0 pulley headers my heads and ported m90 on and im goin need to tune it and i need to fix this pcm problem
  9. #9 Re: pcm done ?
    If you can't communicate with two different devices and the car starts and runs, the problem isn't the pcm. Fix the fuse that FFDP mentioned because w/o power to the OBD2 port...you can't communicate.
  10. #10 Re: pcm done ?
    Max Cook
    Guest
    I had a PCM go bad once where it wouldnt accept any kind of communication/writing to it (even outside of the car) but the car ran normally. Was weird. Replaced it and the new one worked fine.
