Thread: line off of radiator what is it?
Results 1 to 4 of 4
  1. #1 line off of radiator what is it?
    May 2012
    Ohio
    if standing in front of car looking down in. on the left bottom a hose line about the size of a dime goes from bottom left of radiator across bottom of fans then back under right side of engine id guess its a trans cooler line ?? it has about a foot of thicker rubber line that connects to metal line with a connector at each end im asking cause is got alittle leak on it ill try to get a picture i know this is prob not helping you guys much thanks
  2. #2 Re: line off of radiator what is it?
    sounds like a trans cooler line.
  3. #3 Re: line off of radiator what is it?
    If it goes from the radiator to the transmission then its your transmission cooler line
  4. #4 Re: line off of radiator what is it?
    Now follow the line and you will be able to figure out which one it is...then you can get a new one.
  1. 01Cooler Line leaking at Radiator??
    By timboku in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-05-2011, 01:59 PM
  2. GTP radiator fit in GT?
    By dl1027 in forum General Tech Discussion
    Last Post: 09-25-2011, 10:08 AM
  3. Radiator Cap??
    By RegorHtims in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2011, 10:18 AM
  4. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  5. Transmission Cooler Line leaking at radiator
    By Obrigado in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-01-2010, 04:36 PM
