Thread: Shaky steering wheel, loud snap!
Results 1 to 4 of 4
  1. #1 Shaky steering wheel, loud snap!
    Dec 2010
    DMV
    Ok while driving to pick up my friend I noticed the steering wheel was a bit shaky but in my mind I blamed it on the horrible roads in dc. While turning I hear a snap, I immediately pull over and take a look see and I find nothing. Then something says "check the lug nuts" I do and long behold the stud broke off. I look in the street and yup there it is with my lugnut still attached. Can I just replace the stud? Is it pretty easy?
  2. #2 Re: Shaky steering wheel, loud snap!
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    yes jus take a hammer and bang it out and go to a parts store and bang the new back in.. there like 3 bucks a piece.. take the old one and compare it to the new tho.. ive had parts stores sell me some that were to big
  3. #3 Re: Shaky steering wheel, loud snap!
    It's really easy. If you can't get it to move to the right position to change it out grind a little off one side to get clearance to shove it in. Use an old lugnut to pull it through because once that lugnut is used to pull it through you're not supposed to reuse it.
    Dec 2010
    DMV
    Well luckily I remembered that my hub was under warranty put new hub on and all is well
  1. driver's side loud clunk when turning wheel either way!!!
    By Doug 97 gtp in forum Brakes/Suspension/Chassis
    Last Post: 06-03-2012, 10:36 PM
  2. I'd like a new steering wheel
    By gunsn88 in forum General Tech Discussion
    Last Post: 09-13-2011, 11:14 AM
  3. Loud moaning from power steering
    By PTGsDaytona500GTP in forum General Tech Discussion
    Last Post: 11-25-2010, 04:54 PM
  4. Steering Wheel with LED
    By jcl1 in forum Visual/Body Modifications
    Last Post: 10-25-2009, 10:35 AM
