Thread: No brakes...HELP!!
Results 1 to 16 of 16
  1. #1 Re: No brakes...HELP!!
    Feb 2008
    Yeah, when changing the master on an ABS system you have to hook up to the ABS system electronically to bleed the system. Pretty much if you open the system before the ABS system, you going to have to get this procedure done.
    It is possible that when you were working on your brakes that the loss of pressure was enough to make the already bad seals in your master completely fail. But as reminder, if you pushed the pistons on the calipers back without opening the bleeder you could have caused them to fail at that time as well. Either sorry to hear about your bad luck. So I wish you good luck
  2. #2 Re: No brakes...HELP!!
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Since you replace the master cylinder it must be bench-bled which basically you will fill up the reservoir with fluid, connect hoses to each outlet and either have them directed straight back into the reservoir submersed in fluid or into another container with brake fluid, then you slow push in the plunger until no air comes out and it feels good and solid. This can be done with it mounted in the car also but you still use the same proceedure. After you have done this then you can bleed everything else normally.
  3. #3 Re: No brakes...HELP!!
    TDCRacing
    Guest
    Quote Originally Posted by Blown97 View Post
    Didnt even see your post till now. It's at the dealership now so i'll know late monday whats going on with it. I talked to a gm mech.(not at the dealership but online) and he said air in the abs box will make the pedal spongy and the abs won't function properly but the brakes should work.
    Hopefully it doesent cost to much and thats all it is. Maybe when they hook it up to the abs scan tool they can tell me why my abs light has been on (previouse issue) or rather tell me wich wheelbearing it is that's bad. I'm sure thats what it is. This is the second time a scan tool would have come in handy for me. I may look into getting one now. When ever i have the cash.
  4. #4 Re: No brakes...HELP!!
    SE Level Member alacran's Avatar
    Apr 2008
    Chicago, IL
    what method were you using to bleed the brakes?
  5. #5 Re: No brakes...HELP!!
    TDCRacing
    Guest
    The normal method with 2 people and pumping the brakes. I even did the calipers in the order gm specifies it... right rear,left front,left rear,right front
  1. F-body brakes?
    By justwhisen in forum Brakes/Suspension/Chassis
    Last Post: 12-01-2008, 08:20 PM
  2. What rear brakes fit?
    By Berger in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2008, 11:46 AM
  3. Brakes making noise.
    By TDCRacing in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2008, 10:03 AM
  4. problem with R1 concepts brakes?
    By Euro in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2008, 09:39 PM
  5. Powdercoating brakes/mounts [*]
    By kyle99gtp in forum How To Write-Ups/Tech Tips
    Last Post: 12-17-2007, 03:41 PM
