Ford man is correct, was lowered on intrax once and shook after the install. Took the motor mounts out and they were toast. New mounts fixed it. That is of course if you are lowered.
BTW if your replacing one, Might as well replace both. Drivers side mount is the trans mount. The passenger side mount usually looks the worse depending on oil leaks and such.
