Thread: MAF going bad after just 8 months??
Results 1 to 10 of 10
  1. #1 MAF going bad after just 8 months??
    GT Level Member thegipper's Avatar
    grafton, wi
    Hey guys, I replaced my MAF sensor about 8 months ago because it took a crap. Car has run perfectly ever since I replaced the sensor until........
    On my way home last night and my check engine light came on. Fired up torque and read the code. P0102 Powertrain- Mass or volume air flow circuit low input. Car appeared to be running fine still so I continued home (couple miles away). Cleared the code when I got home. This morning I started it up and instantly the code came back on. Same exact code. I decided to drive it around and it appeared to be running ok minus the idle was bouncing up and down a bit. I then gave it a little and it started to totally fumble for a few secs. I decided to drive it home to avoid any more complications.
    I'm assuming everyone is just going to say "replace the MAF again" which is what I'll probably do. Hopefully I have the receipt because these things are NOT cheap. That just seems crazy that it could go bad in just 8 months.
    Anyone have any suggestions? I'm assuming this code is for bad MAF, is there anything else I should do?
    Thanks for the help !
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  2. #2 Re: MAF going bad after just 8 months??
    Have you reoiled your filter lately?
  3. #3 Re: MAF going bad after just 8 months??
    grafton, wi
    No, I have a spectre filter that doesn't get oil
  4. #4 Re: MAF going bad after just 8 months??
    Ok..crappy sensor
    Car-part a stocker
  5. #5 Re: MAF going bad after just 8 months??
    grafton, wi
    Should I just try using some MAF cleaner and try cleaning it out?
  6. #6 Re: MAF going bad after just 8 months??
    grafton, wi
    Ok..crappy sensor
    Car-part a stocker
    Huh? car-part a stocker?
    I wonder if i can find my receipt if Advanceauto will give me a new one since its been less then a year
  7. #7 Re: MAF going bad after just 8 months??
    it's electronic, likely not.
    car-part.com I found an origial (aka stock) for Danielle the other day for $20 locally.
    Advance can usually look it up..and car-parts.com is good for looking about local junkyard Grand Prixs to get a MAF.
    04 Comp G.
  9. #9 Re: MAF going bad after just 8 months??
    grafton, wi
    K thanks Bill. I'll see if I can find a stock one...
  10. #10 Re: MAF going bad after just 8 months??
    grafton, wi
    Brought back my bad MAF to Advance auto and they gave me a new one free of charge. They had my record on the computer so I didn't need a receipt. After work I'll put the new one back in and see if that fixes the problem. Hopefully it should. I'll report back.
    BTW. That is really cool Advance auto does that !
  1. So ive been a member for 2 months and...
    By Black97GTP2dr in forum General Grand Prix Discussion
    Last Post: 06-26-2012, 12:19 AM
  2. 3 CVs in 2 Months?
    By Kasey in forum General Tech Discussion
    Last Post: 06-03-2011, 09:56 PM
  3. HID Bulb Gone In 4 Months???
    By sdavis11b in forum Visual/Body Modifications
    Last Post: 02-17-2011, 08:35 PM
  4. Bad 3 Months
    By EJOUIE in forum The Rant Forum
    Last Post: 06-05-2010, 12:42 AM
  5. What to Do? Old Gas - Car Sat for 18 Months
    By TommyGloves in forum General Tech Discussion
    Last Post: 05-21-2008, 07:17 PM
