you don't want a cam that eats up boost. with e85 you can actually USE the boost and timing so running a NIC would just run you out of pulley options in a hurry.
unless you want to go with the heads/big cam setup then stick with the traditional vs/xp/s1x stock heads setup and run with it. the e85 is going to give you much more gain than you think.
