Thread: orange or green?
Results 1 to 7 of 7
  1. #1 orange or green?
    SE Level Member Mikefisher's Avatar
    Winkler,Manitoba,Canada
    well this may have been brought up before,but is it ok to change to the old green antifrezze?I have heard from many that the orange eats away the gaskets.Can anyone set me straight on this before I go and buy the stuff.Thanks in advance !
    Pike---- Family of rapacious,malevolent,razor-toothed freshwater game fish that will strike instantly and violenty at just about any lure you decide not to try...
    http://s43.photobucket.com/albums/e381/mikefisher99/
  2. #2 Re: orange or green?
    Barksdale AFB, LA
    Dexcool (orange) does not eat gaskets. It is not a corrosive.
    Green, however, doesn't like aluminum parts which is why you see less and less of it.
    2009 Subaru Impreza WRX STI
  3. #3 Re: orange or green?
    Banned
    Wichita Falls, Texas
    Put Dexcool back in.
  4. #4 Re: orange or green?
    sounds good to me thanks guys !
  5. #5 Re: orange or green?
    Feb 2008
    I've changed my coolant to the Green. Take a look at this link and see what issues there are about Dexcool. This has been debated probably since GM started using Dexcool.
    GM Owners Still Steaming Over Dex-Cool
  6. #6 Re: orange or green?
    Barksdale AFB, LA
    And that link makes a good point:
    If your car or truck came from the factory with Dex-Cool, you should continue to use that coolant both as replacement and to top off the radiator, the mechanics say.
    Dexcool does not have problems in a well maintained system. If you have air in your system, it can turn to sludge. Here's a hint... don't let air in! Fix it and don't let it go. Also, it does not erode gaskets. The gaskets were already faulty from the factory. The engines it 'causes' gasket failures on just have crappy gaskets. Why don't you see the Corvette with Dexcool issues? Because it has quality gaskets that aren't going to leak.
    Even more so, other car manufacturers have started using Dexcool. It really is better. And that article is old. Between then and now most of those 'problems' have been explained by other factors, and it was found Dexcool was only the escape goat.
    The only thing that could be changed is the service interval. No one should expect it to last that long. If you flush it at a more sane interval, you won't ever have a problem. Of course, our engines have gasket issues no matter what is in there, so that is beside the point.
  7. #7 Re: orange or green?
    Feb 2008
    ^^^ yeah like plastic gaskets for example
  1. Green Pea from OK
    By buxracing in forum Introductions/Noob Questions
    Last Post: 02-16-2013, 06:07 PM
  2. The Red Green Show
    By Reptile in forum Off Topic Discussion
    Last Post: 01-17-2008, 09:58 PM
