Thread: School me on the Valve Train
Results 1 to 1 of 1
  1. #1 School me on the Valve Train
    GT Level Member Beelzeboul's Avatar
    Racine
    Started getting a slight chatter only under high load and figured my lifters were about ready for a replacement
    Replacing Lifters
    I'm having a hard time working out the lifter ratios vs cam lift
    for most cams 1.60 lift is needed ?
    I know alot of the guys running e85 on stock cams tend to upgrade the valvetrain
    are high lift 1.9 roller rockers an alternative to going with a cam build ?
    what would be ideal if I was planning on swapping to e85 but wanted to leave the option of a cam open?
    if I'm going to be replacing the lifters with stockers should I get higher weight springs to avoid float?
    the way I'm understanding it the increase of lift available is shared between the cams and valve train so going one or the other is just more cost effective
    as opposed to upgrading both for the same gains you could have gotten out of one for around the same price
    most to all cams require some tuning is it required when upgrading to roller rockers as well or would it just lie in wait for a tune?
    I'm sorry officer I didnt know I couldn't do that
  1. Valve train noise problem?
    By rotti3800 in forum General Tech Discussion
    Last Post: 08-13-2011, 11:00 AM
  2. valve train noise-Mysterioussss
    By danomite02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2011, 03:52 PM
  3. valve train tick...
    By jayn in forum General Tech Discussion
    Last Post: 03-19-2011, 07:28 PM
  4. Valve train questions
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2010, 09:54 AM
  5. Valve train questions
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2008, 05:59 AM
