Hey guys, I replaced my MAF sensor about 8 months ago because it took a crap. Car has run perfectly ever since I replaced the sensor until........
On my way home last night and my check engine light came on. Fired up torque and read the code. P0102 Powertrain- Mass or volume air flow circuit low input. Car appeared to be running fine still so I continued home (couple miles away). Cleared the code when I got home. This morning I started it up and instantly the code came back on. Same exact code. I decided to drive it around and it appeared to be running ok minus the idle was bouncing up and down a bit. I then gave it a little and it started to totally fumble for a few secs. I decided to drive it home to avoid any more complications.
I'm assuming everyone is just going to say "replace the MAF again" which is what I'll probably do. Hopefully I have the receipt because these things are NOT cheap. That just seems crazy that it could go bad in just 8 months.
Anyone have any suggestions? I'm assuming this code is for bad MAF, is there anything else I should do?
Thanks for the help !
