Thread: 99 gtp
Results 1 to 8 of 8
  1. #1 99 gtp
    Sep 2012
    Alberta
    Hey everyone the last few days I've been noticing a loud screamy type sound from my engine bay, near the supercharger and the belts, today my sc belt came off... It stayed on around the sc and around the crank but came off the two idlers down below... I took the belt off for now, just wondering what could cause this? Or if I should just get a new belt put on and be done with it...??
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Try and spin all the pulleys and see which one is locked up.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  3. #3 Re: 99 gtp
    Sep 2012
    Alberta
    Seems to me like the supercharger one does not want to spin freely whatsoever... Does this mean I just need to replace that pulley? I hope so
  4. #4 Re: 99 gtp
    If the supercharger is locked up you have to replace it but it more likely is an idler pulley.
    May 2011
    United States
    Quote Originally Posted by 99GrandPrixGTP View Post
    Should spin with some resistance, and make a whooshing sound when you spin it. How are the tensioner and idler pulleys?
    Sent from my Droid
  6. #6 Re: 99 gtp
    Sep 2012
    Alberta
    Idler puller was seized completely, bought all three new pulleys and a new sc belt, should hopefully do the trick, hoping my tensioner is still good
    May 2011
    United States
    You should be fine. Good luck.
    Sent from my Droid
  8. #8 Re: 99 gtp
    Sep 2012
    Alberta
    All is well, thanks
gtp
