Thread: Help!!!!!
Results 1 to 3 of 3
  1. #1 Help!!!!!
    Aug 2012
    Jackson, Michigan, United States
    I have a 2004 Grand Prix GTP. I was crusing down the highway and all of the sudden, my cruise control, and my stereo stopped working. The compass also says its calibrating and my blower motor works intermittently. I checked the fuses inside of the car and they all look good. Is there some sort of relay that can be linked to all of these problems??? It's pretty annoying that I can't listen to music, along with riding around with lackluster heat since the blower motor is also acting up because of this...
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Check to see if you have any power wires grounding out under the hood and make sure the battery terminals are clean and tight.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  3. #3 Re: Help!!!!!
    Aug 2012
    I found the culprit. It was a fuse under the hood. It was labeled under the fuse box as display... So I assumed it was for the dashboard. So I over looked it. Thanks for the suggestion. I know now no matter what the fuse is labeled, DON'T over look it!!!!
