Thread: HELP!
Results 1 to 8 of 8
Matthew Mericle HELP! 10-27-2012, 10:18 PM
Fivefingerdeathpunch Re: HELP! 10-27-2012, 10:27 PM
GTP in RTP Re: HELP! 10-27-2012, 10:55 PM
Matthew Mericle Re: HELP! 10-27-2012, 11:15 PM
Matthew Mericle Re: HELP! 10-27-2012, 11:11 PM
Logan541 Re: HELP! 10-27-2012, 11:25 PM
Matthew Mericle Re: HELP! 10-27-2012, 11:52 PM
KeithGTP03 Re: HELP! 10-28-2012, 12:34 AM
  1. #1 HELP!
    Oct 2012
    Beacon, NY
    I've been searching for about an hour now for a write-up/how to for fixing the light in my trunk on my '02 Grand Prix SE. Can someone link me to one so I can fix it. It has a brand new bulb and it still doesn't work. It's starting to piss me off. I need a link ASAP! Thanks!
  2. #2 Re: HELP!
    What pisses me off is having a thread title that just screams "HELP". But I won't get in to that.
    How about checking fuses. Or seeing if you even have power to the socket.
    Try those.
  3. #3 Re: HELP!
    GTP Level Member
    Oct 2011
    Raleigh, NC
    You need a link " ASAP " to fix a trunk light ?
    1997 Red GTP 182000 miles stock
  4. #4 Re: HELP!
    Oct 2012
    Beacon, NY
    Yes, seeing as I'm not very mechanically savvy. I'm a noob but everyone was a noob at vehicles at one point in their life before they knew everything, sorry. Plus I learn better with pictures/directions. It's just aggravating trying to find something in your trunk at night and your trunk is pitch black.
  5. #5 Re: HELP!
    Oct 2012
    Beacon, NY
    Alright thanks. Sorry for the title.
  6. #6 Re: HELP!
    Feb 2010
    TN
    try the bulb, cleaning the contacts on the socket, then try then the fuses all else fails tape a flashlight to the inside trunk lid and now its miller time
  7. #7 Re: HELP!
    Oct 2012
    Beacon, NY
    Quote Originally Posted by Logan541 View Post
    I might just do that, hahah. If I ever get a new Pontiac I might cut the trunk off w/ the lid and keep it as a beer cooler. Could fit a lot of beer in that big trunk.
  8. #8 Re: HELP!
    Houston
    Yep, check for voltage at the socket. If no voltage there, then continuity test your fuses. Just because the fuse doesn't look broken in that little fuse window, doesn't mean it's not popped. They break at the contacts too and you will never know until you continuity test them.
