Thread: Heater blower issue
Results 1 to 5 of 5
  1. #1 Heater blower issue
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    I got in my 03 gt today and turned on the heat. On all levels the fan is very loud compaired to what it used to be. It kind of sounds like its missing a blade or something. Any ideas what this would be? I did some reading and all I could find is the relay replacement, which I did two years ago.........I have no idea what this is.
    silver 2003 Grand Prix GT List is on it's way to be updated
  2. #2 Re: Heater blower issue
    Nov 2008
    I do have a service engine light on right now. I think it was p0128. probably related but the light came on then a couple days later the noise started. It is a low pinched vibrating sound
  3. #3 Re: Heater blower issue
    Nov 2008
    any ideas at all?
  4. #4 Re: Heater blower issue
    St. Louis
    Probably have something jammed in the cage motor of the blower. Sometimes rodents and whatnot like to chew up the sound deadner and insulation in there and it makes its way into the box, which dumps it into the blower motor. I'd bet if you took it out you'd see junk in it. Just clean it out and reinstall. Sounds like it's out of balance.
    p0128 code [Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)]
    I'd start by replacing the thermostat and bleeding the cooling system and see what that gets you. Sounds like a bad stat.
  5. #5 Re: Heater blower issue
    Nov 2008
    I hooked up the car tonight and it was showing little to no activity on the side two for the o2 sensor. Would this also cause this or is it just also a problem?
  1. Heater blower trouble ....
    By matt1long in forum General W body
    Last Post: 05-06-2016, 07:54 PM
  2. a/c heater blower
    By buschegt in forum General Tech Discussion
    Last Post: 09-25-2012, 05:34 AM
  3. heater blower and hud
    By lokie81 in forum General Tech Discussion
    Last Post: 09-16-2009, 06:27 AM
  4. Heater Blower
    By stratojet in forum General Tech Discussion
    Last Post: 03-22-2009, 09:58 PM
  5. Heater Blower Problem
    By duncanmi in forum General Tech Discussion
    Last Post: 11-24-2008, 09:46 AM
