Thread: What's the best way to test for coolant leaks
Results 1 to 10 of 10
  1. #1 What's the best way to test for coolant leaks
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    When my 06 gets good and warmed up then shut off there is a strong smell of burned coolant. I had to add coolant when I first bought it last spring but haven't had to since (guessing minor leak?), so what is the best way to find out where i'm getting the smell from
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  2. #2 Re: What's the best way to test for colorant leaks
    Mar 2012
    NC
    Pressure test the cooling system with a pressure tester. It can be picked up at a parts store.
  3. #3 Re: What's the best way to test for colorant leaks
    Apr 2011
    Fargo
    Never used one pretty easy or not
  4. #4 Re: What's the best way to test for colorant leaks
    Mar 2012
    NC
    Put adapter on radiator. Pump it up...like putting air in a bike tire. Wait for leaks.
  5. #5 Re: What's the best way to test for colorant leaks
    looks like this.
  6. #6 Re: What's the best way to test for colorant leaks
    Mar 2012
    NC
    looks like this.
    You have a funny looking penis pump.
  7. #7 Re: What's the best way to test for colorant leaks
    19 psi all day lol
  8. #8 Re: What's the best way to test for coolant leaks
    Apr 2011
    Fargo
    Easy enough
  9. #9 Re: What's the best way to test for coolant leaks
    SE Level Member PALMCASTER GT1's Avatar
    PALMDALE CA
    hahaha , that cold hitman.... but funny !!!!
    04 GT1
  10. #10 Re: What's the best way to test for coolant leaks
    PALMDALE CA
    i need to check that also .
    04 GT1
  1. Coolant leaks
    By Kolton Lock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-23-2012, 03:12 AM
  2. List possible oil leaks? :(
    By m17davis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2011, 02:37 PM
  3. Valve Cover Gasket Leaks & Possible Intake Leaks
    By mechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2011, 07:48 AM
  4. Common Oil Leaks?
    By Angleiron in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-08-2009, 08:09 PM
  5. leaks...
    Last Post: 04-21-2009, 10:20 PM
