Thread: Hard starting problem.... but easier with remote starter??
Results 1 to 12 of 12
  1. #1 Re: Hard starting problem.... but easier with remote starter??
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    If it starts perfectly with the R/S and not with the actual key, chances are, it's the R/S wiring or the immobilizer that's causing the issue.
    Put your key into the cylinder, turn the ignition on(don't crank) and remote start it. if it starts flawlessly, your question is answered.
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  2. #2 Re: Hard starting problem.... but easier with remote starter??
    Oct 2012
    Bolingbrook, IL
    I tried turning the key on/eng off waiting, then using the remote starter and got the same results.
    I also hooked up an actron scan tool and watched the ST TRIM and LT TRIM and they stayed within the parameters. Also with the car running, I removed the vacuum hose from the FPR and waited a few minutes and no fuel ever released from it, and also no smell.
    How else can I test the FPR?
    And how else can I see if the immobilizer for the remote starter is the problem? Or is the above post the only testing method? Am I correct in my understanding of what the immobilizer is?.... It's a bypass that's needed if you have a chip in your ignition key?
    Last edited by nicksts333; 10-24-2012 at 02:06 PM. Reason: read more on the subject
  3. #3 Re: Hard starting problem.... but easier with remote starter??
    Oct 2012
    New Jersey
    Quote Originally Posted by nicksts333 View Post
    I meant turn the ignition on and Keep it on, then remote start. This way, both keys are being read at crank time. The immobilizer in GM vehicles is referred to as a "passlock" system. And if activated, it will disrupt the fuel pump from working.
  4. #4 Re: Hard starting problem.... but easier with remote starter??
    Oct 2012
    Bolingbrook, IL
    Quote Originally Posted by JerzNick View Post
    That's what I did. I just said "key on/engine off" because some people refer to that position of the key in the ignition as that.
  1. Starter replaced, still not starting sporadically
    By cboth686 in forum General Tech Discussion
    Last Post: 09-10-2012, 08:07 AM
  2. Remote starter
    By Irving Mosley in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2012, 08:07 AM
  3. Remote Starter issue
    By ajc549FF in forum General Tech Discussion
    Last Post: 09-28-2011, 03:24 PM
  4. Remote Starter help!
    Last Post: 05-03-2011, 11:29 PM
  5. remote starter issues
    By COI in forum Audio, Security & Visual Electronics
    Last Post: 02-03-2009, 11:09 PM
