Thread: Working Under the Car: How to Support?
Results 1 to 14 of 14
Burbman Working Under the Car: How to... 10-23-2012, 10:01 AM
MoarkatsINmuhtrailer Re: Working Under the Car:... 10-23-2012, 10:04 AM
BillBoost37 Re: Working Under the Car:... 10-23-2012, 10:05 AM
Scottydoggs Re: Working Under the Car:... 10-23-2012, 10:06 AM
BillBoost37 Re: Working Under the Car:... 10-23-2012, 10:07 AM
Slick2500 Re: Working Under the Car:... 10-23-2012, 10:11 AM
Scottydoggs Re: Working Under the Car:... 10-23-2012, 10:14 AM
Slick2500 Re: Working Under the Car:... 10-23-2012, 10:17 AM
Scottydoggs Re: Working Under the Car:... 10-23-2012, 10:21 AM
Slick2500 Re: Working Under the Car:... 10-23-2012, 10:27 AM
BillBoost37 Re: Working Under the Car:... 10-23-2012, 10:32 AM
Burbman Re: Working Under the Car:... 10-23-2012, 12:42 PM
BillBoost37 Re: Working Under the Car:... 10-23-2012, 12:47 PM
Burbman Re: Working Under the Car:... 10-23-2012, 01:50 PM
  1. #1 Working Under the Car: How to Support?
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Thinking about a trans filter and fluid change, 98 GT. What's the best way you guys have found to support the car while you are under it? I use a floor jack at the jack point behind the front wheels to jack up the car, but with average size jack stands, you would never get a jack stand at that point, the car would be 45 degrees nose up. Where's the best place to put a jack stand under the front?
  2. #2 Re: Working Under the Car: How to Support?
    Ohio
    front of the subframe...jack stands towards the front corners
  3. #3 Re: Working Under the Car: How to Support?
    Burb... are your stands average for a tractor trailer? I have average sized stands and they will do around 12-18 inches. Works well for most car work.
    I've also used ramps for this type of work.
  4. #4 Re: Working Under the Car: How to Support?
    put your floor jack dead center of the front part of the sub frame, jack car up as high as you can, then use jack stands under the pinch welds where the stock jack would go.
    or just use car ramps to service the tranny.
  5. #5 Re: Working Under the Car: How to Support?
    High enough to pull the trans
  6. #6 Re: Working Under the Car: How to Support?
    I use 2 cinder blocks lol.
  7. #7 Re: Working Under the Car: How to Support?
    like this????? lol
    make sure the holes are up, and not to the side, they are weak when laid on their sides.
  8. #8 Re: Working Under the Car: How to Support?
    No under the frame rails lol. I used to set up mobile homes so I know all about how to set up cinder blocks.
  9. #9 Re: Working Under the Car: How to Support?
    i drove it up there, no jack.
    i was just generalizing the fact of where a cinder blocks strength is and is not. ( you'd be surpised how many have no clue, if set up wrong it can and will crush you) if they had any strength to them with the holes horizontal, buildings would be built with holes in the sides lol
  10. #10 Re: Working Under the Car: How to Support?
    Yup.
  11. #11 Re: Working Under the Car: How to Support?
    There's holes in this theory.
  12. #12 Re: Working Under the Car: How to Support?
    Dec 2008
    ****'s Creek
    Got it, thanks guys! Been some years since I've done any serious wrenching...GP's are '01 (Darling Daughter #1) and '98 (DD #2), both GT's. My buddy owned a 6-bay shop in NY and back when business was good I just told the kids to take the cars in, get fixed, and my buddy would send me the bill. Now living in KY, no buddy near by, and tight on funds. Fortunately still have all my tools (and few new ones from the local HF), just getting familiar with the specifics of these models. I really appreciate you guys taking the time to help me, saving me a lot of grief!
  13. #13 Re: Working Under the Car: How to Support?
    Quote Originally Posted by Burbman View Post
    Once you said Kentucky, I was pretty sure tools said teeth and I was going to congratulate you... lollololol
    Seriously though. Any questions on the easiest, quieckest ways to do stuff...just ask.
  14. #14 Re: Working Under the Car: How to Support?
    Dec 2008
    ****'s Creek
    LOL
    Born and raised on LI, only in Louisville for a year now. Actually DD #2 graduated U of Hartford in 2011. Coincidentally, the trans on the '98 was rebuilt just south of you by Denny Cunningham of Denny's Transmissions in Bristol, CT. Got towed there by AAA after the trans had what was described as a sudden and catastrophic fluid loss on I-84 the day before Thanksgiving in 2008. I forget what let go, but it essentially dumped all of the fluid almost at once onto the exhaust pipe resulting in a whole buncha smoke....Denny did an awesome job, really knew his way around the 4T65E and gave me a 2 yr 24k mile guarantee.
    Just after the warranty expired DD had it towed to a shop in NJ by her BF's house after all forward motion had ceased....turned out an axle seal failed and slowly drained the fluid out. Local tech replaced the seal, filled it up with fluid and it ran perfectly. Made me think it was a good rebuild if you could run it dry with no extensive damage. Once they got it running, they dropped the pan, changed the filter and filled it with fresh fluid. I figured another fluid/filter might be a smart investment at 153k miles.
  1. Motor support?
    By vertebrate in forum General Tech Discussion
    Last Post: 08-20-2012, 01:03 AM
  2. Core Support
    By boothe in forum General Tech Discussion
    Last Post: 03-29-2012, 05:17 PM
  3. lumbar support
    By vincegpking in forum General Tech Discussion
    Last Post: 04-07-2011, 06:44 AM
  4. Needs some GPF support and votes!
    By Swash in forum Off Topic Discussion
    Last Post: 10-07-2010, 02:58 PM
  5. 2-support Mirrors
    By arc in forum 04+ Specifics
    Last Post: 02-08-2010, 02:42 PM
