Thread: very curious engine question
Results 1 to 5 of 5
vtechkiller very curious engine question 10-21-2012, 09:25 AM
stealthee Re: very curious engine... 10-21-2012, 09:29 AM
Toms04compg Re: very curious engine... 10-21-2012, 11:42 AM
Slick2500 Re: very curious engine... 10-21-2012, 12:06 PM
BillBoost37 Re: very curious engine... 10-22-2012, 06:26 AM
  1. #1 very curious engine question
    Aug 2012
    RI
    I was looking at a few other v6s today everything from BMW to Pontiacs. I noticed all of the engines had a different note and tone, and not from the exhaust. for example you can get a l67 and a ford probe gts 2.5 and 1.8 litter and then put the same exhaust set up and the 3800 will be high and raspy and the gt will be low toned to high tone in a continuous hum with no rasp. Why is that? theoretically wouldn't all v6s have the same low tone or on the flip side all the same high tone? for its the exhaust that makes the rasp by back pressure.
  2. #2 Re: very curious engine question
    SWPA
    No. Valve overlap difference, overhead cam vs in block cam, cam difference itself (valve overlap), even the intake set up causes changes in sound.
    Hell a SOHC Stealth/3000GT has a mean deep exhaust note, whereas the DOHC NA sounds high pitched, and the DOHC TT sounds completely different. Those are 3 different 3.0 Mitsusibishi V6's that sound nothing alike.
  3. #3 Re: very curious engine question
    GT Level Member Toms04compg's Avatar
    Michigan
    They sound better stock IMO not to mention your not getting any real gains if any with an exhaust system on these. And some reasons stated above is why not all vehicles with 4, 6 or 8 cylinders sound alike.
  4. #4 Re: very curious engine question
    Hell look at the 3100 compared to the 3800. Anything above idle and the 3800 sounds like ass on pretty much any exhaust setup other than stock. Too much drone and too much rasp.
  5. #5 Re: very curious engine question
    Quote Originally Posted by slick2500 View Post
    Not with a Bonnie muffler
  1. A few curious ?s
    By Dee23 in forum Introductions/Noob Questions
    Last Post: 09-24-2012, 07:50 AM
  2. LIM installed just a curious question
    By W30post in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2012, 04:15 PM
  3. curious..?w
    By Dragonblaze in forum Off Topic Discussion
    Last Post: 11-12-2010, 01:25 PM
  4. Just Curious?
    By sinceregtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2009, 01:58 PM
  5. im just curious
    By occrocks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2009, 08:09 PM
