Thread: 1995 headlight adjust - female torx screwdriver?
Results 1 to 6 of 6
  1. #1 1995 headlight adjust - female torx screwdriver?
    Mar 2012
    Englewood, Co
    My 1995 Prix headlights have the stand male adjustment pins for up/down & left/right...but the local auto stores are striking out regarding the tool to use. It looks like a small 6-pointed star, standard torx maybe? But I need a small screwdriver handle with a female wrench, not a male wrench, and that's the hard part.
    What's normally used? Somebody like Harbor Freight carry these? Thanks for any & all help.
    Tom in Denver
  2. #2 Re: 1995 headlight adjust - female torx screwdriver?
    like this?
  3. #3 Re: 1995 headlight adjust - female torx screwdriver?
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    They are called E-Torx sockets, for External Torx. you can get a set at Harbor Freight.
  4. #4 Re: 1995 headlight adjust - female torx screwdriver?
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    They are also know as "inverted" Torx. It also might accept a phillips head screwdriver in the center for adjustment.
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  5. #5 Re: 1995 headlight adjust - female torx screwdriver?
    Mar 2012
    Englewood, Co
    Thanks everyone - and yes, turns out to be an e-torx. 6mm is somewhat loose on the adjustors but works.
  6. #6 Re: 1995 headlight adjust - female torx screwdriver?
    Dec 2008
    ****'s Creek
    I got my set to change the ignition switch on the 01 GP. There are two 5mm e torx screws that hold it to the steering column.
  1. Geek Alert: Sonic Screwdriver Key Fob?
    By ShadowSwept in forum Audio, Security & Visual Electronics
    Last Post: 08-17-2012, 04:41 AM
  2. Torx socket question
    By blackflag in forum General Tech Discussion
    Last Post: 02-26-2012, 08:32 PM
  3. Fuse box missing female plug?
    By Mitchstrp in forum General Tech Discussion
    Last Post: 10-24-2010, 12:45 AM
  4. Can you adjust the headlight beams?
    By grandprix17 in forum General Tech Discussion
    Last Post: 01-05-2010, 07:57 PM
  5. im new here an im a female
    By Da QueeN GP in forum Introductions/Noob Questions
    Last Post: 09-01-2008, 10:33 PM
