Thread: wot kr...
Results 1 to 10 of 10
  1. #1 wot kr...
    michigan
    So i dont really have any mods and dont plan on it, just have 9" filter hai, and u bend delete. I just got my aeroforce gauge last week and have been playing with it ever since..hehehe. anyways, getting on the freeway this morning i gave it a go up to about 100mph just to see if there were any changes in the readings...and there was. Got up to about 4.5* of kr (normal driving there is zero). Should i be concerned?
  2. #2 Re: wot kr...
    It's stock.
    Not really.
    Are you running 91+ octane in it too? New plugs/wires/t-stat/gaskets/vac lines/fluids/mounts/etc?
    GT Level Member Utter99's Avatar
    Warsaw indiana
    Get headers or a power log . I know you said you don't want to mod but this will make it last longer and flow better . They will pay for themselves by saving fuel eventually . It'll be a little gain but it's worth it.
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  4. #4 Re: wot kr...
    michigan
    Yup 93 octane every time and new plugs, wires etc.
  5. #5 Re: wot kr...
    Never Never Land
    I got about 3* in both my GTP's. Both stock besides an intake.
    You don't have anything to be worried about
  6. #6 Re: wot kr...
    Mounts?
    Flipped upper dog bones?
    Just try to eliminate movement on your setup is all.
  7. #7 Re: wot kr...
    Normal.
  8. #8 Re: wot kr...
    michigan
    Oh....flipped dogbones.
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    when flipping the dog bones is it as simple as it sounds ?
    Sent using my Galaxy SIII on Tapatalk
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  10. #10 Re: wot kr...
    michigan
    So thats a "normal" reading then? Thank god! And flipping the dogbone means rotating the square bushing so its more solid. Not hard but not always an easy task either.
wot
