Thread: Fuel Injectors
Results 1 to 5 of 5
  1. #1 Fuel Injectors
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Finishing up on my UIM/LIM repair and started changing the O-rings on the fuel injectors, when of course one broke. Not the fuel injector, the little plastic piece at the end of the injector called the pintle. A new FI is $89 at Auto Zone, Rock Auto has reman units for $29 after core charge. Then I was reading that it's best practice to replace all injectors if you replace one, so you don't have 1 good one and 5 half-clogged ones producing an uneven power balance due to uneven fuel distribution.
    I found a place in Oregon called Mr. Injector. You send in your injectors, and for $16 each they give them the ultrasonic cleaning, bench flow check, and rebuild them with new filter, O-rings, spacer and pintle. Turnaround is 1 day excluding shipping. He gets them Monday and he ships back Tuesday.
    Anybody use these guys before? I'm sending the 6 injectors from the 98 GT on Monday and will report back.
  2. #2 Re: Fuel Injectors
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    i have a injector that has a broken end peice and i still use it on the car to this day didnt hurt anything still seals and havent had a problem prob have used it for 100K last time i did the intake was at 146 and it has 247 on it now its time for a new intake gasket soon LOL
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  3. #3 Re: Fuel Injectors
    Apr 2009
    Elkhart
    could always buy Bosch Type 3 Fuel Injector Service Kit w/ Pintle Caps | eBay and reuse all ur injectors and replace all the caps and filters and have some left over LOL but then again it is alot of cash for just needing one
  4. #4 Re: Fuel Injectors
    Those plastic things are not needed.
    Install new o-rings and carry on.
  5. #5 Re: Fuel Injectors
    Dec 2008
    ****'s Creek
    Well, that's true. The injector will work fine without the plastic.end piece as that's not part of the mechanism. However it must do somerhng to shape the spray pattern or something or they woulnt bother to put that piece on when they make them. The other thing to consider is that piece was so brittle it split in two and popped of with just slight pressure. If the other 5 are in similar shape I would hate for one of those plastic
    things to get loose and get sucked into the intake.....
    Maybe overthinking this but a cleaning wouldn't hurt them either....what's one more week in the garage?
  1. Fuel Injectors
    By Erik Adam Rodriguez in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2012, 05:10 PM
  2. 97 GTP fuel injectors
    By DSkyles in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 11:22 PM
