Thread: Horn doesn't work, any help?
Results 1 to 15 of 15
  1. #1 Horn doesn't work, any help?
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    So today some jag off pulled out in front of me and I had to slam on my breaks and swerve out of the way to avoid a accident, in that process I went to honk my horn and I got no sound. Thinking I just might of not heard it I waited till I got home and tried to honk my horn again and still got nothing. Any thoughts? Oh also when I lock my car the horn sounds but it is very very faint. You need to basically be next to the car and listening for it in order to hear it. Thanks for the help in advance!
  2. #2 Re: Horn doesn't work, any help?
    Just scream louder out the window.
  3. #3 Re: Horn doesn't work, any help?
    SE Level Member DEM0N's Avatar
    Oct 2012
    Framingham, Massachusetts, USA
    Quote Originally Posted by blueguy91 View Post
    LOL!!! Buy a Megaphone instead & Just Scream at people through that
  4. #4 Re: Horn doesn't work, any help?
    Sep 2011
    Copperas Cove, TEXAS
    Lulz^ Either you have a bad horn or maybe a bad clock spring. Or as mentioned above, yell out window.
  5. #5 Re: Horn doesn't work, any help?
    Aug 2011
    'Merica
    all you need is a large sign and hold it up when this happens....or guns usually do the trick
  6. #6 Re: Horn doesn't work, any help?
    SE Level Member hockey101's Avatar
    Detroit, Michigan
    I had the same problem with my GP not too long ago. It started with the faint lock sound then eventually just all together quit working. How old is your GP? The horns may be starting to go (sounds like they're pretty much gone). Check fuses first, then check for shorts in wiring but if they're all good then it's probably the horns. The horns start to corrode and the mechanical internals freeze up. I had a hell of a time trying to find horns for a decent price that were OEM (or at least sounded OEM). I finally found some on amazon for about $30 a pop.
  7. #7 Re: Horn doesn't work, any help?
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    Just get a dixie horn.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  8. #8 Re: Horn doesn't work, any help?
    Orrrrr just do what I used to when I had my 78 Cutlass Cruizer in high school which was hook up a speaker to my CB and secure it behind the grille out of the way of rain and snow and then press the out button and enjoy yelling at people while they try to figure it out.
  9. #9 Re: Horn doesn't work, any help?
    Oct 2011
    huntley
    Lmfao all these responses are great to read!! But on a serious note I have tried switching all the fuses and making sure all my connections were tight, I have a 04 grand prix so it looks like it is time to get a new horn
  10. #10 Re: Horn doesn't work, any help?
    May 2011
    Kansas City
    Reptile Tune (SOLD)
  11. #11 Re: Horn doesn't work, any help?
    if you have some wires laying around run a wire from the neg and pos to the horns 2 contacts, if it dont go off, then the horns dead, if it does your issue could be in the steering wheel. horn ground popped out or something like that.
  12. #12 Re: Horn doesn't work, any help?
    SE Level Member 99XC600's Avatar
    Apr 2012
    Wilbraham MA
    For what ever reason, my horn does not work until after I hit the thing about 10 times in anger. After the 10th time, everything is good and it's going to toot..toot.
    But by the time it decides to speak up, typically the douche bag has driven away and the moment has passed...lol
    2004 Ivory White Pontiac Grand Prix GT1 - Bone Stock and my 80 mile daily driver.
  13. #13 Re: Horn doesn't work, any help?
    pop the air bag off and check the horn wires.
  14. #14 Re: Horn doesn't work, any help?
    how do i tak the air bag off you may ask, page 2 of this thread.
    http://www.grandprixforums.net/upgra...ols-68892.html
  15. #15 Re: Horn doesn't work, any help?
    Oct 2011
    huntley
    thank you very much! I will take a look!
  1. FAQ doesn't work
    By Jakescoots in forum Forum Bugs/Suggestions
    Last Post: 04-23-2011, 10:41 AM
  2. Help! My horn doesnt work...
    By 97gtpprix in forum Audio, Security & Visual Electronics
    Last Post: 08-18-2010, 04:08 PM
  3. Cig lighter doesn't work! Please help.
    By jimintheb0x in forum General Tech Discussion
    Last Post: 07-26-2010, 01:00 AM
  4. DIC doesn't work at all.
    By hubert hefner in forum General Tech Discussion
    Last Post: 05-29-2010, 10:32 PM
  5. Speedometer doesn't work HUD Does??
    By josh0261 in forum General Tech Discussion
    Last Post: 11-27-2009, 10:17 AM
