Thread: Tires or Axles (Vibration)
Results 1 to 20 of 24
  1. #1 Tires or Axles (Vibration)
    GT Level Member jake91's Avatar
    Jun 2012
    mesa az
    I'm getting this vibration from my car when i get above 60mph it doesn't get bad till 75mph though. now if i hit the throttle around 80mph it will shake hard enough to rattle things in the car, and once i let of it goes back to just a vibration. it doesn't do this at all under 60mph, and the acceleration shake doesn't start till 75+. I am thinking bad tires or a CV axle.
    thoughts car has only 60k miles
  2. #2 Re: Tires or Axles (Vibration)
    Rotate your tires and see if it gets better
  3. #3 Re: Tires or Axles (Vibration)
    Jun 2012
    mesa az
    i did that once about 2 months ago before it got worse and it seemed about the same but i rotated them back because i got a tire pull
  4. #4 Re: Tires or Axles (Vibration)
    Indianapolis
    Axles If it only does it while accel at 75+
    GT Level Member Cocor's Avatar
    Aug 2012
    Collinsville, il
    Axles. My 02 GTP did that. Was worst when turning right and on the throttle.
    2005 GP GXP Ivory White, OBX Headers, Cat and Muffler delete, HP Self Tuned, De-badged/Custom LS4 badges, K&N CAI, Intense Poly upper mounts, Strut Tower Braces, HSRK, HID 8000k headlights, Switchback LED front turn signals, interior LED's. Dyno'd @ 275whp/275wtq
  6. #6 Re: Tires or Axles (Vibration)
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    If it is your axles make sure when you get new ones they have 5 ribs in the boots and are the same length as your old ones. DON'T buy GSP axles NAPA brand or dealership seem to be the only ones that work.
    I went NA when a whore left -$300 in my bank account.
  7. #7 Re: Tires or Axles (Vibration)
    Jun 2012
    mesa az
    Well i feel so freaking stupid. this is embarassing. the vibration is all my fault due to me neglecting the gtp for a couple months. i took it to discount today to air up the tires and they were all 20lbs low and unevenly worn as a result. still need to get them rebalenced. but it is a ton better with just air
    so laugh all you want and make fun of me. i deserve it
    GT Level Member Utter99's Avatar
    Warsaw indiana
    Happens to the best of us
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  9. #9 Re: Tires or Axles (Vibration)
    SE Level Member Garrett Mofford's Avatar
    Oct 2012
    Cincinnati
    mine does the same thing.. steering wheel shakes so i know its the front end.. i was told the wheel bearing was bad?
  10. #10 Re: Tires or Axles (Vibration)
    Quote Originally Posted by Garrett Mofford View Post
    I would make sure your tires are in good condition, not seperated and are balaced correctly.
    If its still there, I'd look into an axle issue.
    Wheel bearing shouldnt cause the steering wheel to shake.
  11. #11 Re: Tires or Axles (Vibration)
    Oct 2012
    Cincinnati
    when im on the highway an i hit 55-60 steering wheel shakes and then if im on a highway that has a slight right turn i can hear and feel a slight thud thud thud thud haha but only turning right.. on my front right tire i can move it side to side when the car is jacked up.. i can only move it a **** hair tho.. but still dont seem right
  12. #12 Re: Tires or Axles (Vibration)
    Side to side is a loose tie rod, likely an outer.
  13. #13 Re: Tires or Axles (Vibration)
    Oct 2012
    Cincinnati
    your a very smart man tonight!!
  14. #14 Re: Tires or Axles (Vibration)
    Jan 2012
    Philadelphia
    Hes always a smart man when it comes to GP's lol
  15. #15 Re: Tires or Axles (Vibration)
    Oct 2012
    Cincinnati
    Quote Originally Posted by gtpeddie View Post
    haha and so ive realized.. looks like i found my main man haha
  16. #16 Re: Tires or Axles (Vibration)
    when you change it, leave the jam nut on, break it loose and thats it, twist the new one on to the old nut, tighten it up, then go get a alignment. i'd change both sides.
  17. #17 Re: Tires or Axles (Vibration)
    Oct 2012
    Cincinnati
    but also when i had car jacked up today i seen that the previous owner doesnt know what a pinch weld is used for.. Dumb A** -___-
  18. #18 Re: Tires or Axles (Vibration)
    Oct 2012
    Cincinnati
    there only 13 bucks for a pair.. might as well..
  19. #19 Re: Tires or Axles (Vibration)
    id pay more then 13 for a pair lol you get what you pay for.
  20. #20 Re: Tires or Axles (Vibration)
    Oct 2012
    Cincinnati
    totally agree but are there any difference? haha dont jump down my back to much just a rookie thats curious
  1. Axles???
    By GRAND98 in forum General Tech Discussion
    Last Post: 07-13-2012, 09:10 PM
  2. What CV Axles to use
    By indygrandprix in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2012, 04:49 PM
  3. Bad Axles?
    By lflylow in forum General Tech Discussion
    Last Post: 10-20-2011, 08:57 PM
  4. Don't buy these axles!!!!
    By 01RedfireGT in forum General Tech Discussion
    Last Post: 06-29-2009, 11:32 AM
  5. Axles
    By starscr33m in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2009, 09:59 PM
